Old 04-26-2006, 12:25 PM
sblkcamaro70 sblkcamaro70 is offline
dpfi vs mpfi
boy as if there isn't enough questions and info about the swap out there...... my question tho is will i sacrifice mpg doing the swap? i wouldn't think so because if you are shooting the same air/fuel ratio you wont drop, and since the mpfi has 4 injectors it is more precise in the injection process versus the 2 injectors. alot of you have done the swap and i am wondering your experience with your mpg gain/loss
Old 04-26-2006, 01:28 PM
turtlecrxsi's Avatar
turtlecrxsi turtlecrxsi is offline
Send a message via AIM to turtlecrxsi
Re: dpfi vs mpfi
Yes you will sacrifice some mpg but it'll no longer take you 30 seconds to get to 60mph either. The dpfi is primarily one main fuel injector with a back up that adds extra fuel during higher rpms. The mpfi is like you said a fuel injection system.
I have lots of mods on my d16a6 and still average 33-36mpg
2008 KIA Spectra5 SX
2010 Honda CR-V EX
Old 04-26-2006, 01:53 PM
bambam89lx's Avatar
bambam89lx bambam89lx is offline
AF - Advisor
Send a message via AIM to bambam89lx
Re: dpfi vs mpfi
you serious?
The reason why you want to do an mpfi swap is to increase power. Generally, increasing power = losing MPG.
Seriously, you drive a 4 cylinder honda. There are plenty of turbo hondas that still get 25-30 mpg. So no matter what, you will still be getting good gas mileage.
Jumper harnesses, mpfi conversions, engine harness conversions, vtec subharnesses, etc.
The absolute lowest prices at the absolute highest quality. Trusted. Guaranteed.
Click the image above to visit our online store!
Hastings Bseries and Dseries piston ring kits (inc. ZC) - $49 shipped
Old 04-26-2006, 02:01 PM
Re: dpfi vs mpfi
yep i know i would still get great mpg, but i am not like a lot of u guys that are going strictly for horse power numbers. i am going for mpg numbers. i was curently thinking about a mpfi swap with the vtec-e head or would i be able to keep the dpfi?
Old 04-26-2006, 07:47 PM
2poor2tune's Avatar
2poor2tune 2poor2tune is offline
Send a message via AIM to 2poor2tune
Re: dpfi vs mpfi
dont worry you will still be way up there for the mpg. so its no big deal
Old 04-26-2006, 08:10 PM
Kven's Avatar
Kven Kven is offline
Re: dpfi vs mpfi
I know the HF,VX, CX, and HX use MPFI. It's possible to get better MPG with the MPFI manifold because the DPFI manifold makes a right angle turn, which probably causes the air to tumble and reduces low-throttle port velocity(best fuel economy=efficiency at part throttle/low rpm).
For the DPFI vs. MPFI, economy-wise, it depends on which manifold you use. The DPFI(B2) manifold has small runners compared to my D15B-VTEC manifold(pretty much a Z6 manifold).
The A6, Z6, and Y8 have the largest of the bunch. If you get a B6(HF), B7(EG DX), B8(CX) or Z1(VX/HX) manifold/map it shouldn't really effect the MPG too much. The B6 and B8 are the 8-valve engines IIRC; those would get better MPG than the D15B2 to begin with.
HondaSwap | K20A.org | EF Honda
1988 Honda CRX DX
WTB: CRX mudflaps(both front and rear)...PM me if you have some for sale!!!
Old 04-26-2006, 09:32 PM
Shaguar47's Avatar
Shaguar47 Shaguar47 is offline
Send a message via AIM to Shaguar47
Re: dpfi vs mpfi
The DPFI is nothing of a true fuel injection, but it does have one primary fuel injector. It is basically just a souped up Carburator, thats all. MPFI is true fuel sequential injection as it has 4 injectors. You probably will lose some mpg but in turn you are gaining a better power band and more precious engine running. It also depends on what else is on the car. You could always throw the std 4spd or hf's 5spd on there and get a good mpg car with the added value of 4 injectors. But then again you could always get the hf model and just do some upgrading to run it off the si ecu. Either way, dpfi is not the way to go unless you want good ol mpg gains.
1990 Black Geo Storm - RIP -
1990 Blu metallic Std Hatch
1999 Milano Red Ex Coupe
Current -- Ex to Si. It's Overdone, but who gives a crap. I don't!
Old 04-26-2006, 10:09 PM
Re: dpfi vs mpfi
so i have a b6 motor and the whole wire harness. would that intake manny boost power over my currrent dpfi setup?
