| Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible. |
how to adjust tps
Hi all.
I was having a really bad problem with high rev going to 1200rpm some days, then 1500rpm then I adjust the biss via "only" a screwdriver and lower the revs, but later was the rev's up anothergain till I end up to 2100rpm !! and wasting a lot of gas 2 tanks in a week, when I usually use 1 1/4 tanks. I check the tps with a multitester and was ok, then try to ajust the tps, but in my manual there was no adjusting procedure, so I adjusted moving counterclockwise close to the end, and then the revs went down to 1000rpms! much better like day and night, all the threads I check don't say how they finally solve the problem. 1- I need your help how to adjust the tps sensor with a multitester 2- what brand of pocketlogger to do all the adjusting (digital tuning, inc? http://pocketlogger.com/index.php?pid=obdii) 3-Can I solve the check engine light with the pocketlogger? my car is a 2g with a 1g motor( no cranck sensor) Thanks for your time pk |
Re: how to adjust tps
In the 3rd point can i solve the check engine light with a pocketlogger because I have a 1g motor in a 2g car (code p0300 engine misfires)
1) High idle isn't ALWAYS sensor related but in your case it most likely is, is it a constant high idle or more like idle surge? Have you checked the ISC yet?
2) You can't make any adjustments with a pocketlogger, it does what it says, it takes logs of what your engine is doing. If you want control of what your car is doing then I would recommend DSMlink. 3) There is a "self-check" option on the car when you throw a CEL, it deals with turning the key on and off a few times and watching how many times the CEL blinks, I belive there's a how-to in your owners manual about that. For your random misfire code, read up on this. The article is at the bottom of the page labeled "Problems!" http://www.magnusmotorsports.com/article_1g2g.htm |
Thanks gt
>1) High idle isn't ALWAYS sensor related but in your case it most likely is, is it a constant high idle or more like idle surge? Have you checked the ISC yet? It is constant high idle, I change the ISC and the high idle didn't change (I'm using the new good use one), I check also for air leaks found one and fix it and I still have a small one around the biss bolt. ( need O ring ) The tps was at the the center of the total adjust I had to go nearly all counterclockwise. if I put it all clockwise the revs will go up and down , up and down maybe is a lean condition? but nearly counterclockwise drop the revs to 1100-1200, I made a test by taking off the top part of the ISC and made the adjustment manualy by turning the isc shaft to the right side and the revs drop I believe the isc trys to center that shaft and goes on a rich mixture, maybe I'm going to get a new tps since my car is a 110,000 miles >2) You can't make any adjustments with a pocketlogger, it does what it says, it takes logs of what your engine is doing. If you want control of what your car is doing then I would recommend DSMlink. >3) There is a "self-check" option on the car when you throw a CEL, it deals with turning the key on and off a few times and watching how many times the CEL blinks, I belive there's a how-to in your owners manual about that. For your random misfire code, read up on this. The article is at the bottom of the page labeled "Problems!" http://www.magnusmotorsports.com/article_1g2g.htm I believe I read that "self-check" is for a 1g, doesn't work on a 2g I already check that site before with no good luck, my alternatives is going with a 93-94 hall efect CAS or the dsm link will get disable that randon misfire. And for the TPS adjusting anyone? thanks gt Last edited by pedrokim; 04-28-2006 at 12:32 AM. |
I remember to adjust the tps on Haynes about a year a go, don't now where I put it but I found this site http://www.roadraceengineering.com/2gtbswap.htm, it really help me adjusting and lower my rpms, to the botom of the site you will see the procedure
hope it helps pk 1995 awd eagle talon, Apex N-1 exhaust system, jdm engine,14turbo, msd wire plugs 1997 gst 62,000 miles, 1g motor, 14turbo, k&n filter, 1g crushed bov 1994 awd eagle talon 65,000 miles wating for road race preparation |
