Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 04-26-2006, 09:29 AM
eddie6937 eddie6937 is offline
1997 Bonneville will not start
My Bonneville SE will click, but will not turn over. My battery seems to be fine, and anti- theft is off.
Please help!!!!!!!!!!!!!!!
Eddie
Old 04-26-2006, 02:11 PM
maxwedge maxwedge is offline
A990 racer
Re: 1997 Bonneville will not start
Try jumping the starter at the solenoid.
Old 04-27-2006, 12:07 PM
sixsmiles sixsmiles is offline
Recommend you jump battery even is you think it is OK, also comfirm battery and starter connection.... If you have a Volt meter 12.6 or above at the battery should eliminate the battery, then connections, and finally jumping the solenoid of the starter to see if the starter rotates.... Finally replace the starter.
Old 04-27-2006, 12:16 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
How did you determine that the battery is good? Have you attempted to jump start the car? If it's the newer style gear reduction type starter, don't try the old mechanic's trick of whacking the starter with a hammer. All that will do is break the starter's ceramic magnets and ruin it. Make sure all your battery connections are clean and tight. If all connections look good, it's entirely possible that even though the battery has good voltage, it cannot deliver the amperage to turn the starter. Max's suggestion of jumping the starter at the solenoid will verify it.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 04-28-2006, 05:44 AM
auto trainy auto trainy is offline
Also double check the + battery cable for corrosion (very common problem)
