Old 04-26-2006, 07:59 AM
AmatureCDV Driver AmatureCDV Driver is offline
Send a message via AIM to AmatureCDV Driver
Burning Oil
Ok, so i have a 92 gtp with the 3.4 dohc and i am burning oil. It isnt a lot of oil, but it is signifigant enough to make me worry. I am wondering what are some possible sourse of burning oil, the only one i can think of is rings, and how can i check to see if its that. I really hope it isnt rings because i dont want to have to fix that. also, if i take out the spark plugs, i can check for oil, and that will tell me if its the rings right? thanks for the help.
Old 04-26-2006, 08:21 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: Burning Oil
By burning oil, I assume you mean that you see bluish white smoke coming from the tailpipes, correct? To check if it's rings, you'll need to do a compression test. Run the test and record your readings, then squirt oil in each cylinder and re-test. If the compression readings go up after the oil is added, the rings are the cause of your burning oil. If adding oil to thte cylinders changes nothing, then you probably have a burnt valve or two, bad valve guides, or even possibly a head gasket starting to go.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 04-26-2006, 03:49 PM
StevePT StevePT is offline
Re: Burning Oil
Check your plugs and see how they look. If they are coat with a lot of carbon residue, than your oil burning problem is most likely bad rings or intake valve guides.
If the plugs look good then check around the intake manifold to see if oil is leaking from the rocker valley out past the manifold. Not sure if that motor had the same oil pump drive gear the 3.1/3.8L motors have, but that o-ring can contribute to losing some oil over time.
