Old 04-26-2006, 08:15 AM
phil a phil a is offline
2001 slow start sometimes/cranks too much
I had fuel replaced under warranty at the dealer..,,
new fuel filter installed,,
#207 relay installed,,,
fuel pressure guage connected to fuel rail NOTED;
Sometimes with the key on just to bring dash accessories
light on the the guage dont move untill I turn off then on again!
the 2nd time the guage shoots up to 35lbs ,, engine start fine,,
runs at 33lbs,,, max out at 40lbs @2000 rpm
If I jump in and start cold it cranks like 12-15 revs
If I start cold ,BUT turn key on/off/on /off ,then it
starts fine,,, sounds like another relay sticking ?
Old 04-26-2006, 09:53 AM
road_rascal's Avatar
road_rascal road_rascal is offline
Send a message via Yahoo to road_rascal
Re: 2001 slow start sometimes/cranks too much
Just a thought- have you tried swapping the battery for a known good one? I have seen batteries that show good voltage but fail under a load. I don't always hear the fuel pump prime on my '01 Windstar when I turn the key on also, same with my '99 Taurus
Old 04-26-2006, 10:18 AM
12Ounce 12Ounce is offline
You might try the PCM power realay. It takes both relays, (Fuel pump and PCM power) to energize the pump.
Old 04-26-2006, 01:00 PM
LeSabre97mint's Avatar
LeSabre97mint LeSabre97mint is offline
Phil
You might want to see where powere is and where it isn't when you have your key on and do not see gauage movement or fuel psi. Take a test light or mulit meter and probe around.
Regards
Dan
Wiswind's Windstar repair pics http://community.webshots.com/album/201931518cScpNK
Photos of my repairs: http://dansautopictures.shutterfly.com/
Check this out:http://threewheelmotorcyclemetro.shutterfly.co
A must read about problems Windstars have: http://www.automotiveforums.com/vbul...d.php?t=672854
95 Windstar 240,000+
98 Windstar 136,000+ 09-25-2008.
85 Dodge 1 Ton Snow mover gas hog
91 Mazda Protege free beater
SW MN
