Go Back   Automotive Forums Car Chat > Renault > Clio/Clio II/Clio III
Old 04-26-2006, 12:17 AM
bonedavid's Avatar
bonedavid bonedavid is offline
clio bonnet ***alert***
i have just seen Watchdog program on BBC1 which covered the problem with bonnets flipping up due to an inadequate poorly designed catch.
http://www.bbc.co.uk/consumer/tv_and...20060425.shtml
Watchdog has received other complaints of bonnets opening unexpectedly on the Renault Clio, specifically on models ranging from 1997 to 2001.
Since 2001, Renault Clio's are now fitted with a modified bonnet catch.
Martin Woodhouse, a mechanic with more than 30 years experience, explained to Watchdog that the Clio's safety catches for these models are inferior in both design and quality.
Renault are reluctant to admit a problem as it will cost them thousands if a recall is made.
If you own a Clio (1997-2001) I would recommend checking the bonnet latch mechanism operates freely and cleaning and lubricating with WD40 or similar
I would also recommend anyone who has had this problem to contact VOSA who will investigate and could recommend a recall to Renault.
http://www.vosa.gov.uk/vosa/apps/rec...outrecalls.asp
It is the responsibility of the manufacturer to inform the Vehicle Inspectorate when substantial evidence of a safety defect that requires remedial action, has been confirmed. Additionally, evidence may be presented to the manufacturer by the Vehicle Inspectorate as a result of investigations into accidents, and safety defects which have been brought to their attention from other sources.
Email :
[email protected]
THIS IS A POST FROM A MEMBER ON THE UK FORUMS..
I dont know if you guys have clios over there but the advice is sound for all renaults apparently
http://www.renaultforums.co.uk/gener...t-catches.html
SEE THE FULL THREAD HERE http://www.renaultforums.co.uk/gener...t-catches.html
