Go Back   Automotive Forums Car Chat > Oldsmobile > Ninety Eight
Old 04-25-2006, 06:16 PM
krazyken2 krazyken2 is offline
Exclamation TBI Engine
How do you know if you have a TBI engine???? I'm trying to follow this repair manual, for replacement of the TPS sensor, and it has different repair listings for different engines?? Just need to know if my 1990 Olds 98 Regency 3.8 L is a TBI engine, so I can replace this freakin sensor!
Man I hate these electronic cars!?? Sensors up the corn hole! LOL
Ken
Old 04-25-2006, 06:43 PM
maxwedge maxwedge is offline
A990 racer
Re: TBI Engine
Not tbi it is a sfi, check autozone.com/repair info for an online manual.
Old 04-26-2006, 04:12 AM
Re: TBI Engine
TBI ENGINES
To remove the TPS on these engines, disconnect the electrical connector and remove the two attaching screws. Make sure throttle is in normal closed idle position then install the TPS on the TBI assembly. With the TPS lever located ABOVE the tang on the actuator lever, install the attaching screws using a thread locking compound. Reconnect electrical connector. No adjustment is necessary.
http://www.autozone.com/servlet/UiBr...3d800d33d1.jsp
Ken
Old 04-26-2006, 08:05 AM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: TBI Engine
A car with throttle body injection will look like it has a carb. on it. The air cleaner usually sits on top of TBI and if you have TBI just remove the air cleaner. If it looks like a carb with an injector or two sticking out of it then it is TBI. Otherwise you have multiport fuel injection.
Old 04-26-2006, 02:05 PM
A990 racer
Thumbs down Re: TBI Engine
Originally Posted by krazyken2
TBI ENGINES
Ken
Olds tbi 3.8's never had tbi from 1985 forward. I checked the link it is for a 5.7 98 truck??? Lots of time wasted for all here!
Old 04-27-2006, 08:01 PM
Re: TBI Engine
Ya man!???
Ken
