Old 04-25-2006, 02:03 PM
Webb Webb is offline
Power Antenna
My power antenna no longer works, so therefore I no longer have a radio. Where should I start looking? I have checked (or I think I have checked you tell me) all the fuses and they are all fine. (fuses in the dash)
Please help - going crazy without some tunes.....
Old 04-25-2006, 02:58 PM
yogi_123rd yogi_123rd is offline
Re: Power Antenna
You didn't check fuse panel number 2.
Fuse panel 2 has all the relays and fuses for those "extra" features you have.
Fuse 2 in fp2 controls the power antenna. I believe either the door locks or the security system also works on that fuse. Do you have something else not working?
The fuse panel is located under the glove compartment and in the right corner. You need to remove the kick panel (3 wing nuts - 4 screws) to get access. The glove box can swing out (so you can at least see a little bit).
Fuse 2 is the second fuse down from the left top. (I think it's 15amp)
Old 04-25-2006, 03:36 PM
Loekee75's Avatar
Loekee75 Loekee75 is offline
Send a message via Yahoo to Loekee75
Re: Power Antenna
The power antennas for these cars are known for going out, are you sure it's not the internal band that broke inside the pwr antenna housing? Also check your relay, it is connected to the power antenna assembly.
http://www.cardomain.com/ride/2653398
1992 Buick Park Avenue (Daily driver)
2001 Saturn SL1 (gas saver)
Old 04-25-2006, 03:43 PM
Re: Power Antenna
Thank you I will check both of these and let you know.
Old 05-05-2006, 08:21 AM
Re: Power Antenna
The only fuse panel I found is as you open the driver side door the fuse panel is right there. No fuse panel underneath the glove box.
Old 05-05-2006, 08:23 AM
Re: Power Antenna
Where would I look for any fuses for the power antenna and what kind of fuse would it be?
