Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 04-25-2006, 10:40 AM
yourshadow24 yourshadow24 is offline
trans parts swap
anyone know if it's possible to swap the trans parts out of a 91 4l60 trans to a 94 4l60e? i'm referring to the gears and such.
Old 04-25-2006, 10:55 AM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: trans parts swap
Yes, that should work - the internal mechanics of the transmissions (clutch packs, drums, gearsets etc.) were the same between the two models.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 04-29-2006, 10:48 AM
Blue Bowtie's Avatar
Registered Offender
Many of the parts are the same even back through the later versions of the TH700-R4. Whatever you do, however, DO NOT re-use the reaction sun shell. Spend the extra forty bucks for a TCI "Beast" sun shell with the heat-treated hub. The '91 was among the suspect years for this part.
Just watch the stack heights for the plates and steels, since the counts and thicknesses varied across the years.
