Old 04-25-2006, 10:38 AM
mehrshadvr4 mehrshadvr4 is offline
Angry why?
why our car spun bearing so easy? every time i check the 3si, i see someone just spun some bearings.now i am worry about my car.
Old 04-25-2006, 10:57 AM
talskinyguy talskinyguy is offline
Send a message via AIM to talskinyguy
Re: why?
Generally because of running rich or not changing the oil. Fun stuff like that.
A few "bolt on" mods, a couple "cut, smash, hammer, weld, etc" mods, and a couple "why the hell do I need this/what the hell is this" weight reductions.
Old 04-25-2006, 11:03 AM
Re: why?
i thought runing lean is bad not rich.i am runing rich now
Old 04-25-2006, 11:41 AM
Re: why?
Running lean causes knock, and breaks/shatters shit.
Running rich cause gas in your oil. Gas in your oil reduces its ablility to lubricate and will cause spun bearings and excessive wear on everything.
Old 04-25-2006, 09:59 PM
Hotshot8792 Hotshot8792 is offline
Re: why?
That is definitely one cause, but also another cause is the fact that a lot of people don't change out their oil pumps, and when it starts to weaken, the oil pressure will drop, which also causes a lack of lubrication. I already had a friend of mine not listen to me and he learned the hardway.
Anyways, try not to run rich, keep up with the maintenance on the car, and try to run like 15W-50 oil in your car, and you should be fine.
Daily Driver: 2004 Jeep Grand Cherokee Special Edition
1994 Mitsubishi 3000GT SL-TT Automatic - Black
3.05 L Arias Forged Pistons, Pauter Forged Rods, DR Stage 3 heads, 3SX TD05 kit w/ E16G's, CX Racing FMIC, 550cc injectors, Walbro 255lph pump, + supporting mods
1994 Mitsubishi 3000GT VR-4 - Black
Intake & Boost Controller so far
2006 Sea-Doo RXP Supercharged, Updraded SC, IC + supporting mods
Old 04-25-2006, 10:14 PM
TorchedStealth's Avatar
TorchedStealth TorchedStealth is offline
Send a message via MSN to TorchedStealth
Re: why?
My car is on its 3rd engine and its from spun bearings. Is the oil pressure supposed to be between those 2 lines that are a little longer than the others? Because mine is a little below the bottom long line at idle and a little above at normal driving. Could this be my oil pump?
2005 Saturn Ion Redline - Injector Dynamics 1000cc Injectors|E85|Harrop TVS1320 Blower|2.9" pulley|3" Intake|Vibrant Header and catless Downpipe|Hahn 3" catback|N2MB Wot Box w/2-step and no-lift shift|Cobra Heat Exchanger|Hurst STS|Ottp Stage 1 trans mounts|AEM EUGO Wideband|Aeroforce Interceptor|HPTuners (self tuned)|Mop Top Pros Carbon Fiber badges|B&G Springs
Old 04-25-2006, 11:59 PM
AutostradaVR4 AutostradaVR4 is offline
Re: why?
Could be your pump, but before screwing with it, consider the following.
The stock oil pressure gauge it GARBAGE. Do yourself a favor and get an aftermarket. Compare the readings on the stock next to the aftermarket, youll see what i mean, they will be totally different.
Formerly BlinkRA182
--VR-4-- --09 Lancer RALLIART-- --Me--
Old 04-26-2006, 12:18 AM
Re: why?
True, and also you can try a heavier weight oil and see if your pressure starts to rise.
Old 04-26-2006, 03:31 PM
Re: why?
Ok thanks guys. So what oil do you think i should put in there when i get it changed? (keep in mind it will be summer driving of course)
Old 04-26-2006, 04:18 PM
Re: why?
I personally run Mobile 1 synthetic 15W-50, but the weight is all up to you. I think a 10W-40 will suite your needs just fine. Of course, you could go up to 15W-50 as well if you'd like.
However, i do recommend that all TT owners should run at least 15W-50 synthetic oil. I have talked to several TT owners as well to discuss this, and some of them that said that they have never had a bearing problem with their car say they use 15W-50.
