Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 04-25-2006, 07:52 AM
mrtooter mrtooter is offline
No Spark 3800 apv helpppppppppppp!
Van just quit on highway - is this any indiction on were to look?
new crank sensor put in,about 4 used ignition modules, back probed all the wires in ignition circuit to the computer for continuity, all is well, checked all the fuses including 20amp in engine compartment, fuel pressure if good, injecters are comeing on when cranking, checked all grounds and cleaned them, did a diagnostic test from shopkey5 still no spark,
any ideals on were else to look my wife is driving me nuts this is her van to get all the grandkids and drive me nuts even more. a lose , lose situition lol
think hard what havnt i checked? thanks in advance
Old 04-25-2006, 08:36 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: No Spark 3800 apv helpppppppppppp!
check the harmonic balancer to see if it separated and re-check the crank sensor for a signal. Just because you recently replaced it doesn't mean it isn't bad.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 04-25-2006, 08:35 PM
balancer looks ok , any ideal how to check the cranks sensor while its hooked up?
Old 04-26-2006, 09:31 AM
richtazz's Avatar
unplug the connector, hook up your ohm meter to the crank sensor, and have someone crank the engine. The ohm meter will detect a change in resistance in the sensor as the shutter on the balancer passes through it if it's working. Also double check the wiring harnesses at the ICM. They are fairly common to get corroded, or it's easy to bend them while intalling a new module.
Old 04-26-2006, 11:13 AM
were exactly should i put the ohm meter and should it be set on ohms or volts/ thanks for your help ,
Old 04-26-2006, 01:25 PM
richtazz's Avatar
set it to ohms. There are 4 spades in the sensor itself, and each adjacent pair controls 3 cylinders. The crank sensor is a dual hall effect switch which sends a signal to the ECM each time one of the reluctor blades on the harmonic balancer passes through it. You must insure that the harmonic balancer doesn't touch the crank sensor. If your van is 93 or older, the crank sensor is adjustable, and the air gap needs to be set when installing the sensor. If it's misaligned, it can allow the balancer to hit the sensor, causing it to fail and the van to stall. To test, put the red probe of your multimeter on the outside terminal, and the black on the terminal next to it, and crank the engine. the reading should change as the harmonic balancer reluctor passes through the sensor. Test the other half in the same manner. If you get no difference in reading, then the sensor is bad.
Old 04-26-2006, 05:09 PM
my van is a 93 with a new gm rebuild 3800 engine , the crank sensor does not appear to be adjustable as it sits on a pin in the middle and has a bolt on each side. im willing to buy a new icm but i have tried 3 or 4 used ones from the junk yard with no luck, we have spent 3 full days doing tests on it, its not worth spending alot of money on so any help u can give im very thankful for.
Old 04-27-2006, 10:19 AM
SAGE12 SAGE12 is offline
Send a message via Yahoo to SAGE12
IT NOT THE ICM
I'M HAVEN SAME PROB ON MY CENTURY
I HAVE NEW CRANK SENSOR NEW ICM & NEW CEM NO CHANGE
Old 04-27-2006, 10:20 AM
IT NOT THE ICM
Old 04-27-2006, 02:14 PM
jeffcoslacker's Avatar
jeffcoslacker jeffcoslacker is offline
Lactose the Intolerant
"The power of Christ compells you..."
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made...
...empty gun rack.
Old 04-27-2006, 03:39 PM
every car is different ,i over look nothing im beyond the basics, time to get down and dirty, i need some high tech help!
Old 04-27-2006, 03:46 PM
Run an alternate 12v supply to the ICM and see what happens....
...empty gun rack.
Old 04-27-2006, 07:05 PM
i dont recall 12v going to the icm only 5.5volts from the computer,, i ran a bunch of tests provided by shopkey5 who gets them from general motors
i have entire wiring diagram and all general testing methods,
Old 04-27-2006, 08:43 PM
Yeah, I think you're right.
Check continuity of the coilpacks yet?
...empty gun rack.
Old 04-28-2006, 05:43 PM
i have replaced entire assebbly icm and coil packs as a unit, mind you they were all used from the scrap yard, and one that was known working
Closed Thread
