Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 04-25-2006, 05:39 AM
bluemoon541's Avatar
bluemoon541 bluemoon541 is offline
MAP sensor question...
okay...ive got a 96 civic DX...thats D16Y7... the MAP sensor has gone bad...what other engines have compatable sensors?....from what other engine may i be able to pull a MAP sensor from?
Old 05-03-2006, 03:00 AM
93civicsiracer 93civicsiracer is offline
Re: MAP sensor question...
wwhen it comes to sensors just get the same things. i dont know if theres any diff in map sensors but im leaning more toward each sensor having there own reading. think an ecu has certain settings to run each engine. a map sensor messures the amount of air going in the car. and tells the ecu to make adjustments. what do u think
Old 05-03-2006, 10:37 PM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
any obd2 map sensor will work for sure.
thinking about it, any obd1 sensor should work too. the differences will be in wiring coloring.
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
