Old 04-25-2006, 03:57 AM
JimBee JimBee is offline
'96 air-con control panel lights
My Cherokee's have not worked since getting it. My son has the same truck,and his panel lights up as per normal,when you turn on the lightswitch. I took the dash of today,well not right off,enough to undo the 4 screws holding it in place,and slide it oiut a few inches only,to try and see the 'bulbs'. Could not see them,or where they might be hidden,so then when I went back and turned my son's truck lights on,to compare, I noticed the the light appears to be actually inside the very front black plastic strip facia,itself,and cant be got at!! Would this be right? do I now need to get another whole new complete unit,if this is the case? or are there small bulb/s in behind,and I just need to take the unit right out,to find them......oh boy oh joy...!!
Old 04-26-2006, 12:04 AM
mrbill3's Avatar
mrbill3 mrbill3 is offline
Re: '96 air-con control panel lights
The bulbs are in the rear of the control unit. You will have to remove the mounting screws and pull it out then you can get to the bulbs.
89XJ Laredo, 2 door, 4.0L, Automatic. Rusty's 3" Full-Spring Pack Lift, Steering Stabilizer, Bumpstops, Steering Brace, and Adjusatable Track Bar. ProComp 31X10.5X15 AT's on 8" Steelies. Dynomax Super-Turbo Cat Back.
Old 04-26-2006, 12:24 AM
Cheers mrbill3,thanks for that, I now know they are there...thanks again...Jim
Old 04-27-2006, 06:33 AM
I had my mechanic do it,he found that the bulb had somehow come out of the socket,and now is back in place,and works fine!!
