Old 04-24-2006, 12:49 PM
angel_iz378 angel_iz378 is offline
Send a message via MSN to angel_iz378
Question smelling gas
Could anyone tell me why, other than a fuel leak, I could be smelling gas inside my 94 cavy. It's mostly when I run the heat i smell it only on the interior of the car, but there is also the very faint smell on the outside whenever I cut the car off when I don't run the heat. (I don't know if the A/C affects it or not b/c it doesn't work.) My gas doesn't seem to be affected so I don't think it's a fuel leak. Maybe something in the fuel pump?
I love humanity. It's people I can't stand.-Gil Grissom
Check out My NEW 2007 Cobalt LT "Pheonix" @ Car Domain
Old 04-24-2006, 02:11 PM
Cold_Silence's Avatar
Cold_Silence Cold_Silence is offline
Send a message via AIM to Cold_Silence Send a message via MSN to Cold_Silence
Re: smelling gas
Does your engine compartment or anywhere under your hood smell like gas? Is there a gas leak anywhere or somehow u got gas under the hood? Check out fuel injectors and anywhere that could have a bad seal and leak gas. That could be the case and it could just be bringing the gas smell thru the vents when ur heat is on. Hopefully its something simple but I think its a sign you are leaking gas somewhere and its wafting the smell through your vents..
The New Ride!! 2002 Cavalier Coupe..
Originally Posted by noshun
It's a lovely 2200, but got about as much poke as my grandma with no fingers.
www.cleanstartsolutions.com
