Old 04-24-2006, 10:16 AM
thebroken thebroken is offline
95 headlight relay - where is it?
Ok I have replaced both headlight motors and they worked great for several weeks and now the left one is grinding whne going down (not up) and I'm being told its the headlight relay.
Any idea where this is on the car?
Thanks
John
Old 04-24-2006, 10:53 AM
frizbal frizbal is offline
Send a message via MSN to frizbal Send a message via Yahoo to frizbal
Re: 95 headlight relay - where is it?
Thanks
John
The grinding noise isn't from a relay. Its the gear inside the motor being stripped. you should insert a brass gear inside.
http://www.bfranker.badz28.com/headl...htm#MetalGuide
thats a good site to do so.
Old 04-24-2006, 11:40 AM
gmack221's Avatar
gmack221 gmack221 is offline
Did the cover come back off? I had my epoxy'd covers come back off, I redid it and then make a metal bracket that uses the 3 mounting bolts to hold the cover in place.
Old 04-24-2006, 04:07 PM
I bought 2 rebuilt ones off ebay from ft lauderdale moter lift- a company i have used before.
They have brand new gears inside and did work perfectly. I would like to look into the relay, thats what stops the moter from spinning when already down.
any feelings?
Old 04-24-2006, 04:55 PM
Once i did mine they stayed on. The bracket seems like a good idea. If mine ever comes off, ill probably just screw some small screws into the top.
Old 04-24-2006, 05:01 PM
any feelings?
If it doesn't have the brass gears, its still handy to get them. And if you do have to replace the "relay," its still too late for the gear (since its grinding). It too will need to be changed. But im not sure about the relay. I'll look into it when i have some time.
