Old 04-24-2006, 09:42 AM
JstCloseUrEyes JstCloseUrEyes is offline
Gas Gauge not working
Hello,
well thats not specifically correct, it will read from full to just about empty, randomly however, sometimes while I am driving it will just bob up and down, until it settles about a half tank.
So, really I have no idea how much gas I have.
I spoke to my mechanic, he said to look for a Troubleshooting Guide for the gas gauge, either in a manual, or online.....so, that is why I am here asking for help
Thanks a lot everyone!
2000 GP GT ~ Super Turbo Mufflers ~ Custom Dash ~ Owned by Poor College Student ~ Not Much Else Done ~ Saving for WS6 :-D
Old 04-24-2006, 09:47 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: Gas Gauge not working
Originally Posted by JstCloseUrEyes
Hello,
Fuel level sensor in the gas tank is bad. I have never seen a bad fuel gauge.
Timeslip 08/12/06
AF Community Guidelines
Old 04-24-2006, 09:56 AM
Thanks, i didnt htink it was the gauge, just didnt know how else to desribe it
Now, is this something that I can do myself, IE, with my girlfriend's father, or do I have to drop the gas tank to change the part?
Speaking of, how much would the part cost me?
Old 04-24-2006, 10:00 AM
BNaylor's Avatar
Yes. As you can see I did mine DIY. There is an access cover behind the rear passenger seat in the trunk. Move carpeting and sound deadening material and you'll see it. Seven 10mm nuts hold the cover. The complete fuel pump pod will come up and out after disconnecting the fuel lines, evaporative emission line, electrical connectors and the big C-Clip retainer. You can get the level separately or the whole pod which will come with the level sensor and float. Around $90 or so just for the sensor. Whole fuel pump pod can be expensive at around $300.
BTW - It will be very dirty so use a shop vac and clean up otherwise you'll not see the c-clip. You don't want dirt dropping into the fuel tank. Good luck!
Also disconnect battery negative cable before working on the fuel system.
Timeslip 08/12/06
Old 04-24-2006, 11:00 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Bob, as always, is correct. Just for reference, the AC-Delco part numbers are as follows for a 2000 GP GT:
fuel pump (includes level sensor) : MU232 (gm#25325702) $421.92 @ dealer
fuel level sensor only: SK1028 (gm# 25323814) $160.64 @ dealer
I work at a Delco distributor in Flint, MI and can sell them at $210.96 and $80.32 respectively, + s/h. If you're interested, you can PM me with your zip code and I can give you a shipping quote too. Whatever you do, don't buy Advance and Auto-Zone's ""Master" brand. I used to work for Advance and the Master Brand is JUNK. Airtex isn't much better either, so try to stick with AC-Delco or Carter if you can.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
