Old 04-24-2006, 10:20 AM
miker14 miker14 is offline
windshield wipers
windshield wipers will not shut off.
what is causing this?
how do i fix this?
thanks for your help.
Old 04-24-2006, 10:25 PM
Alibi's Avatar
Alibi Alibi is offline
Send a message via Yahoo to Alibi
Re: windshield wipers
Year of car? There could be a relay that is stuck open (if the circuit has a relay) causing the wipers to stay on.
-Eric
89 LeSabre T-Type: CAI, STB, F41 Suspension, Moog Ball joints and tie rods, dual-out flowmaster and dual tips, Pointiac CD HU, Delco type 2 Ignition, etc.
Basic H/C body info:http://www.3800power.bravehost.com/index.htm
http://www.cardomain.com/ride/2318168
Old 04-27-2006, 10:13 AM
The car is a 2003 buick lesabre
Old 04-29-2006, 02:04 AM
Alibi's Avatar
New for my blood
Anyway, you'd either have a bad wiper module (which you may or may not be able to replace separately, is inside the wiper motor assembly itself), a bad column switch, or back to a relay. The easiest thing to check first would be a relay...for your year of car I believe the relay center is in the enginebay somewhere towards the firewall. It should have a cover over it with a diagram of what relay is what. Try swapping in a relay for a known good circuit for your known bad circiut (wipers).
You may want to do a search of the forums for more information too since my info is a bit dated (see sig )
-Eric
