Go Back   Automotive Forums Car Chat > Chrysler > LHS
Old 04-24-2006, 08:52 AM
Marialyce Marialyce is offline
tran acting funny after a swap.
I bought a 96 Chrysler LHS that needed front body work, the 3.5 motor was replaced with a 3.5 motor from a 94 Newyorker. It shifted fine when I got it home, but now it keeps falling out of overdrive and then wont shift into gear from park. While it is acting this way it whines really loud., It doesn't always do this. Is it a computer malfunction due to different year motors?
Old 04-25-2006, 11:18 AM
neon_rt's Avatar
neon_rt neon_rt is offline
Re: tran acting funny after a swap.
Usually a loud whining is caused by a damaged front pump.
If the input shaft was "jammed" during the motor replacement, it can damage the pump. The pump will whine and the fluid pressure may be low b/c the pump is leaking internally. The pumps are very fragile. I ordered a shift kit for mine and it comes with a ring that screws onto the front of the trans to re-inforce the input shaft area to help prevent damage when you put it back together.
Old 04-29-2006, 07:32 AM
Thanks! I plan on getting a good used tran. and have it put in. The guy that I bought it from did it himself with a buddy and they didn't hook up alot of sensors and vacuum hoses, so it is entirely possible that they ruined the tran. Thanks again!
Old 05-26-2006, 04:48 PM
Blacky72 Blacky72 is offline
Send a message via MSN to Blacky72
Hi Fellas!!! how the things going??? Hope Fine.... about a swap.....does any knows about a swap a 3.8l from a towm country into a LHS 1996...can fit???and the trany???
Old 08-17-2006, 05:07 PM
RE: the 3.8 town and country tran. sorry it took so long. I haven't been on in awhile. If your still wondering, When I was looking for a tranny I was told that only a tran from a 3.3 or 3.5 ,96 or 97 only,
Old 08-17-2006, 05:54 PM
Hi Folks!!! I´was talking about all, engine and tranny also.
Old 08-19-2006, 12:24 PM
AWP9521 AWP9521 is offline
Blacky72, your better off staying with the 3.5 engine, it actually has more power than the 3.8 engine.
The transmission in all LH body cars from 1993 to 2004 (Eagle Vision, Dodge Intrepid, Chrysler Concorde, New Yorker, and LHS) are unique to that body style, they are not interchangable with any other transmission from a front wheel drive vehicle. Primarily because of the longitudinal (sp) drivetrain placement instead of the transverse layout, turning the engine/transmission sideways in these vehicles would be a total nightmare electrically, and fabrication wise.
Originally Posted by AWP9521 - 02/16/2005
Sure sex is a thrill too, but your modified car will never tell you
"Sorry honey, I just don't feel like it tonight" it will always be in
the garage silently waiting for you to hop in so it can thrill you
some more, that is unless you break it. At least they're easier
to repair and get the thrill back than a pissed off girlfriend.
Old 08-19-2006, 06:54 PM
Thanks AWP9521!!!!
Old 09-20-2009, 10:55 PM
redneckpat1977 redneckpat1977 is offline
maybe im just dumb and not understanding all of what i am reading but here i go i have a 1996 lhs trany was working fine until the battery lost connection fixed it and now trany is in limp mode i have replaced two sensors on the trans and still no speedo and still stuck in limp mode i dont get it help
