89 gmc sierra oil getting in throttle body
i noticed that my truck was blowing smoke when i start it up and taking off.
i looked at the mount that holds the air cleaner on the throttle body and there is oil in there . there is a hose in the back of that mount that goes to the driver side valve cover , (it not the pcv valve). the oil is coming from there . does it supposed to do that. thanks |
Re: 89 gmc sierra oil getting in throttle body
It will if you have excessive blowby |
I would start by changing your pcv valve and see if that stops the problem. If it is excessive blow by you will have to have the engine rebuilt or replaced, becasue there is either something wrong with the cylinder walls or the piston rings.
NO 4 N JUNK ![]() 1994 GMC K1500 XC 5.7L 2008 Chevy Impala LTZ |
wouldn't the engine run bad or something , it idols smooth and runs pretty good at all rpms.
It is servicd to the full mark and not overserviced correct? |
i replaced the pcv valve and cleaned the hose from the pcv valve to the moter . i still not getting any vacuum , could it be cloged some where . how would i clean it out .what do you think. thanks for your help
