Old 07-17-2002, 04:10 AM
fogeesiksteythree fogeesiksteythree is offline
Send a message via AIM to fogeesiksteythree
Question difference between blowoff valve and wastegate?
it might sound stupid but wuts the difference between a blowoff valve and a wastegate? whats the difference in wut they do and wuts the difference in the parts?
Old 07-17-2002, 04:39 AM
ales's Avatar
ales ales is offline
Forza Schumacher
You won't believe it, but I was abou to post the same question!
My current understanding is that a wastegate lets some exhaust gasses pass into the exhaust bypassing the turbo and a blowoff valve lets extra pressure escape from the inake.
Looking for a more detailed explanation now.
Old 07-17-2002, 10:42 AM
ivymike1031 ivymike1031 is offline
Send a message via AIM to ivymike1031 Send a message via Yahoo to ivymike1031
Sounds like you've got it right, ales.
Come on fhqwhgads. I see you jockin' me. Tryin' to play like... you know me...
Old 07-17-2002, 11:25 AM
454Casull 454Casull is offline
A blow-off valve releases the pressure that builds up when the throttle valve closes. A wastegate diverts exhaust before it hits the turbo when boost reaches levels too high.
Some things are impossible, people say. Yet after these things happen, the very same people say that it was inevitable.
Old 07-18-2002, 12:04 AM
hey ales, i think ive figured it out. i knew wut a wastegate was, but i wasnt sure about a blow off valve. wut a BOV does is that it lets air out when the throttle plate is closed. if there isnt a BOV, then the air would go back towards the comprssor wheel in the turbo and if the air were to hit the wheel, it would slow it down since its spinning in the opposite direction. hope that helps
Old 07-18-2002, 12:09 AM
ales's Avatar
Forza Schumacher
Yes, I knew that, I was just hoping someone would come up with pics and drawings and elaborate on the mechanism that both of these involve (well, BOV is pretty straight-forward, but a wastegate, i suppose, is more complicated?)
