Old 04-23-2006, 04:19 PM
gftb5's Avatar
gftb5 gftb5 is offline
Help please
I have noticed recently that when i drive in directions that pull the my car right, my car makes a squeaky sound like the brakes are worn, when i am not even touching them. This happens also when i am driving straight and the grooves in the road pull my car right slightly. I hear the whistle, metallic sound of something. I had my breaks looked at, and they are fine. It has to do something with else. Any ideas?
Old 04-23-2006, 04:39 PM
philly rs's Avatar
philly rs philly rs is offline
Send a message via Yahoo to philly rs
Re: Help please
hey what size tires do u have on your car? im asking because i have 18's and wide tires tend to "track" when u are driving. its not as bad with the 16's i have on for now, but im sure 17's and bigger do it. my car does that bad when i git grooves in the road, but thats what u get when u go big. if u have small wheels i dont know what to tell u, like i said my 16's i have now dont do it much at all
Your import sounds like my ass after a night of mexican food..
And spraying aint cheating, its brining a gun to a knife fight!!
yeah, its a v6 RS...never mind the f1 badges lol
HYPSI87 u will be missed
Old 04-23-2006, 05:53 PM
stieh2000's Avatar
stieh2000 stieh2000 is offline
Re: Help please
Being pulled to the right could be a result of your steering being out of aligment.
Old 04-23-2006, 06:01 PM
Mr. Luos's Avatar
Mr. Luos Mr. Luos is offline
Firebird Guy
Re: Help please
Is a tire rubbing?
Any wider tire will 'track'.
My Grand Am is worse than my Trans Am is now. Grand Am is only 225's on a 16" wheel.
T/A has 315's out back and 275's up front. 17" wheels.
Wheel bearing is something else to think about.
1999 Pontiac Trans Am WS.6 #1747
Stock'ish'
Old 04-23-2006, 10:41 PM
instantkevin's Avatar
instantkevin instantkevin is offline
Send a message via Yahoo to instantkevin
Re: Help please
you're talking about two different things. philly, your right, but he's talking about something else... a noise. i think it could be your steering knuckle... possibly. I know on my car the inside rim of the wheel is incredibly close the the steering knuckle (milimeters). and it will rub against the wheel slightly when the angle of the wheel is changed (like, after i lower the car from a jack stand).
check the inner edge of your wheel and see if it has been grinded down a little bit.
90 Camaro RS V6 - swapped to V8
-350 block, GM Vortec L31 Heads, Edelbrock Performer RPM Vortec intake, 750cfm carb, CompCams XE268 Camshaft
ESTIMATED 360-420 hp 380-430lb/ft torque
Old 04-24-2006, 10:19 AM
92zcamaroperson's Avatar
92zcamaroperson 92zcamaroperson is offline
Re: Help please
what he said. and look for anything loose that could move around your wheels or engine bay for that matter.
92 z28 camaro 5.7 TPI
current - slp intake runners and base-BBK 52mm throttle body-MSD 8.5mm wires, blaster coil, and 6AL Box-edelbrock headers-160 degree stat.-hotchkis strut tower brace
waiting in the garage - LQ4, milled heads 317 casting (10.5 to 1), hardened pushrods, ported LS6 oil pump, manley dual spings with titanium retainers, MTI X1 cam, hawks longtube headers
Old 04-24-2006, 10:41 AM
iroczman's Avatar
iroczman iroczman is offline
Re: Help please
sorry a little off topic but instantkevin what size cowl do you have?
Old 04-24-2006, 11:35 AM
Genopsyde's Avatar
Genopsyde Genopsyde is offline
The President
Send a message via AIM to Genopsyde Send a message via Yahoo to Genopsyde
Re: Help please
My guess is either a siezed up caliper, or a bad wheel bearing. After driving for a while, get out and touch the wheel that's dragging, if it's hot to the touch, then it's the wheel bearing and should replace it asap. it'll be warm, that's normal, but if it's HOT, it's a problem.
