Go Back   Automotive Forums Car Chat > Oldsmobile > Bravada
Old 04-23-2006, 05:06 PM
duffmorgan duffmorgan is offline
1994 Poor accelleration/stumbling
Newbie Member
Original owner, 235,000+ miles
Background: 150,000 new fuel pump, new distributer @ 220,000, regularly scheduled servicing.
Problem(s):
Driving on the highway passing car at 75mph and lost accelleration. Car was running and was able to pull off the road. Car was towed to my mechanic for repair.
Car is running but the accelleration is poor -- stumbles when pulling out from a stop, merging or passing. It stumbles when cruising on highway at speeds of 60+, no gas smells, etc.
Starts up find and the idle is good-smooth, good around local town slow driving. Must do gentle (feathering) accellerating when starting out from a stop. No hard accelleration.
Mechanic checked:
Fuel pressure, cat converter, timing, distributer.
Replaces:
Distributer Cap, router, ignition wires set, oxygen sensor, A/C spark plugs.
Mechanic Note:
SMALL coolant leak at intake manifold gasket -- had this for a few years.
Is it time to go to a Dealer for life support????
Thank you ahead of time for your help.
Craig & Kerry Seibert
PS We love the 94 Bravada and we have a 2002 also.
We really want both of them on the road.
Old 04-24-2006, 09:16 AM
dcg9981 dcg9981 is offline
Re: 1994 Poor accelleration/stumbling
I had a similar problem that involved a agas line that runs inside the plenum of the intake to the fuel injector unit, I had no gas smell but it was leaking in the intake pretty bad, might check it, part is cheaap, and change the oil after .
Old 04-24-2006, 06:29 PM
ericn1300's Avatar
ericn1300 ericn1300 is offline
AF Premium User
yeah a common problem, but don't get ripped off big time by your mechanic like i did. here's a link to a previous forum that will tell you what to check for and how to fix it.
http://www.automotiveforums.com/vbul...=fuel+injector
Old 04-24-2006, 07:23 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Welcome to the site,
I'd check the MAP sensor and Throttle Position Sensor (TPS), idle to full open values.
Off the subject but same car, how has the transmission held up through the years?
