Go Back   Automotive Forums Car Chat > Dodge > Ram Van
Old 04-23-2006, 02:10 PM
timothyhampton timothyhampton is offline
86 Ram Van Overcharging!
Hi all, My '86 B150 is overcharging and cooking the battery. The old alternator went bad a month ago and I replaced it. No problems untill a week ago when the ammeter started showing a high charge rate intermittingly. Now, it shows a high charge all the time. I replaced the regulator this morning and it still is overcharging! Any Ideas? Thanks!
Old 04-23-2006, 04:16 PM
stamar stamar is offline
Re: 86 Ram Van Overcharging!
you purchased the wrong alternator?
Old 04-23-2006, 04:50 PM
The alternator I got was an OEM reman. 60 amp just like the old one. I've been checking every wire in the charging system, they're all okay. Still, I'm getting almost 15 volts to the battery constantly! All my book says about overcharging is to replace the regulator which I did with no difference.
Old 04-24-2006, 01:29 PM
slantsixness's Avatar
slantsixness slantsixness is offline
Something is wrong with the replacement alternator. possibly one field is shorted to ground, like the old insulator is cracked on the spade tab.
If I knew what I did to break it, I would've known not to do what I did.
www.classicwinnebago.com
Old 04-26-2006, 07:43 PM
Slantsixness, Thanks for the tip, I'll check it out!
