Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 04-23-2006, 02:01 PM
Swansen Swansen is offline
Send a message via AIM to Swansen Send a message via Yahoo to Swansen
a few issues (speedometer, door panel)
OK the first issue, the speedometer doesn't work could be the gauge is broken, not hooked up, or a friend said to check/replace the a relay for the speedometer, can't remeber the exact name, but i don't know where it would be.
second issue is kinda dumb but the driverside window won't go up all the way so i figure the tape is broken but i don't know how to get the window handle off to take off the panel
thanks for any help
Old 04-23-2006, 07:56 PM
saturnspeed_12's Avatar
saturnspeed_12 saturnspeed_12 is offline
Re: a few issues (speedometer, door panel)
sounds like your gauge cluster needs replaced. if the speed sensor goes out, the pcm should set a ses light if it does. what year is your car?
now about the window crank removal, its best to get the tool to do it because other wise you get to go at it with a thin flat head screwdriver.
here is the clip..............
here is the tool...............
here is how it works, if it helps (MAKE SURE YOU GET BETWEEN THE PLASTIC WASHER AND THE HANDLE!!!!).........
Ian
Saturn Tuners Club-OH Chapter President
1993 Saturn SC2 rebuild project for dad
1995 Saturn SL2 current daily driver /w a lot of work
2007 Chevy Cobalt injen cai, full lsj exhaust, dc sports fsb, progress springs and rear sway bar, enkei wheels/hankook rubber --*boost in progress
Old 04-24-2006, 01:27 PM
its a 94 and i do need to check the code because the check engine light it on, anyways thats a great tip i've never had a picture from a reply.
thanks i'll try that and check the engine light and reply back
the check engine light was for a swith on the transmission and air cleaner box, on another note, takeing off the interior door panel was pointless, i need to take off the exterior door panel to figure out the window issue.
Old 04-26-2006, 02:01 AM
sierrap615 sierrap615 is offline
Master Tech Wanna-be
nice picture on that door
does the odo/trip work?
Daily driver: 1995 Buick Regal Custom 3.8L 4T60-E 150K miles
Gone: 1994 Saturn SL2 1.9L MP3 168,666 miles
EPA 608 Universal Certification
EPA 609 Certification
Old 04-26-2006, 09:14 AM
no the trip/odo doesn't work because the speedometer doesn't work
