Cleaning Coolant Overflow Tank
I got this 2003 Venture and have never ever changed out the coolant, so I decide to completly clean out and flush the system. The only problem I'm having is trying to clean the overflow tank. I washed it out with water but cant get this black buildup cleaned off the the inside of the tank with plain water. Is there anyway to clean this off with some special cleaner or technique?
Also I got ALOT of rust/corrosion under the hood of my 2003 venture with 86K miles, is this typical in these vans, because I also got a 2002 Impala with way more miles and no signs of corrosion whatsoever. |
Re: Cleaning Coolant Overflow Tank
I've heard of people using really hot water and some bleach type cleaner - pour it in put the cap on and shake it up. Or, you can mix a little dishwashing detergent with a little Clorox and hot water. But I think even with that you'll have to get a bottle brush or the like and scrub a bit to loosen it up and scrape it off. Be careful shaking that tank with bleach it in - might want to wear eye protection.
My 2003 Montana looks pristine under the hood. What exactly is rusting? I'm in Indiana, so we don't have as much salt in the winter as some states, and I always wash under the hood when I wash the car. Good luck...Glen |
I'm in chicago illinois and this thing is corroding EVERYWHERE ! I can't understan why as soon as I got it it started rusting.
Is the hood rusting? It should be an aluminum skin, but aftermarket ones are often steel. If you got this used, any chance the front end was damaged and rebuilt, and they didn't paint/protect it right? Odd....again, mine looks brand new (but it does only have 33K on it)....Glen
No the engine compartment is rusting only; NOT the hood. BUT the hood does have alot of stone chips. The engine is rusting more and more as time goes buy, soon this thing will be a real rust bucket.
When i cleaned it I used acetone. It'll evaporate completely when your done. Just swish it around a little at a time and all the sludge will come right out. Of course follow all safety precautions, it's nasty stuff.
Thought for the Day… Alcohol does not make you fat - It makes you lean... against tables, chairs, floors, walls and ugly people. ![]() If a prostitute here in America loses her job to a prostitute in India , is that considered "outwhoring"??-Jay Leno |
