Go Back   Automotive Forums Car Chat > Mercury > Grand Marquis
Old 04-23-2006, 01:13 PM
JerryR JerryR is offline
Central Locking problem
I tried to reset my central locking so the doors would not lock when the vehicle started to move. Something has gone wrong and now the doors lock and unlock randumly. How can I reset the door locks to default. Should I disconnect the computer? If so, shere is it?
Thanks, Jerry
Old 04-23-2006, 06:29 PM
cobradude360's Avatar
cobradude360 cobradude360 is offline
Send a message via AIM to cobradude360
Re: Central Locking problem
what i would do is disconnect both battery cables and touch the cables together WITH THEM DISCONNECTED FROM THE BATTERY and touch them together with a wrench or something metal this will ground out all the power in the memory system thus when you reconnect the cables 15 to 30 min later all your settings will be reset to factory the way ford had it of coruse you will lose your radio settings and mpg calc if you have digital gauges but hope this helps
THE 92 grand marquis LS M75 with the 281 romeo v8 u cant mess with that
MODS: dynomax bullit exhaust, custom intake, polished upper plenum, 180T-stat, accel coil packs and platnum plugs
also 2005 crysler sebring sedan walter p crysler edition yea its got the 2.4 pics comin soon
Old 04-25-2006, 09:29 PM
reekor reekor is offline
I agree only if you don't have any aftermarket audio amplifiers or capacitors installed in the car. If you have a cap in there that could turn very ugly.
His, 96 Limited, 5.2 Magnum, Magnaflow CatBack System, HID Head & Fog Lamps, 242 T-case swapped , Rear Trac-Loc. Chrome grill added to match the wheels.
Hers, 96 Limited I6, 242 T-case, HID Head & Fog Lamps.
Old 04-27-2006, 09:58 PM
Disconnecting the Battery is a great idea, unfortunately it did not work. Yes indeed, I did short the two connectors together for about 15 minuets. Still no good. I finally have removed the 20A C/B under the hood and killed the whole Auto lock feature (along with the power seats) I will drive with only manual locks until I can find a solution. Jerry
Old 05-15-2006, 11:37 PM
OldsBuickGuy82 OldsBuickGuy82 is offline
Thanks, Jerry
I'm interested in this topic, my Crown Victoria has the AutoLock feature as well, and I've been wanting it disabled too. The manual describes how to do this but it only works until the next time I start the car then it's back to locking when I shift from R. Your problem seems like it might be something like mine so if you ever figure out how to fix it please post here.
Thanks
Old 08-17-2006, 11:14 PM
Thanks
I still have no solution. I changed the door module but the same problem exists. Jerry
Old 08-23-2006, 03:28 AM
2OOOLS 2OOOLS is offline
Send a message via ICQ to 2OOOLS
I am sorry but what EXACTLY happens now with you door locks?
Old 08-23-2006, 05:17 PM
I'm not the original poster, but I think we have the same problem. Some models have a feature when you shift from R the doors lock autmatically. And, although there is a description in the owners manual on how to stop this, neither of us are able to make it work.
Myself, I can get it to work, but only until the next time I restart the car, then it reverts back to locking at shift from R again. The only reason it should revert back is if the battery gets unhooked again....
Old 08-24-2006, 12:02 AM
My doors will lock and unlock ramdomly. Sometimes up to 10 times a minute. I have changed the Door Module but no change. Jerry
Old 08-24-2006, 01:06 AM
Hmm... So basically you are saying that door locks start to lock and unlock when you:
-just insert the key inside ignition switch
or
-turn the key and start the car
just by themselves? without you touching anything? while you are driving? shifting a gear? braking?
Since you said that you changed DRIVER DOOR MODULE (DDM) my rough guess is that you have Power Door Lock/Unlock Circuit Failure somewhere.
Is all of your wiring closed by the trim panels on the right and left side?
Any loosen wires/connectors? did you check all 3 right side ground bolts?
Did you check left side ground bolt?
Is the RH bulkhead electrical connector properly connected and its bolt tightened?
PS. All these questions I ask because I had slight failure of door locks when I removed Instrument Panel. Then after I checked everything out it was fixed.
Old 08-24-2006, 02:42 AM
or
After I start the car they are totally random. I will check all these points. I have not done any work on the car and everything is in place. Where is the Left side ground bolt? Jerry
Old 08-24-2006, 02:55 AM
ground bolts are behind LH and RH cowl side trim panels. but if you did not touch them they probably ok. you might need also to tighten the bolt on RH bulkhead electrical connector.
Old 08-24-2006, 03:05 AM
ok, i think i know whats going on.
You said you installed NEW DDM...
Upon installation of a new lightning control module (LCM) or driver door module (DDM), the module must be reconfigured. Did you reconfigure it?
Old 08-24-2006, 03:11 AM
No. I just plugged it in. Jerry
Old 08-24-2006, 03:23 AM
Since you would need a scan tool for this my best bet probably would be to make a stop by the local mechanic and ask him whats going on then.
You may want to ask him to use Customer Preference Items method of module configuration.
This method is used to enable or disable module-controlled items or systems to suit the preference of the customer. Not all features controlled by the module are listed in this configuration method. Refer to the Module Configuration Index for a list of features per module (they are Autolock and Horn Chirp)
Also keep in mind that:
If an item is changed using the customer preference items configuration method, the changed information will not be stored in the PCM VID block. The VID block will retain the original settings as they were recorded when the vehicle left the factory.
