Old 04-22-2006, 10:59 PM
TwentyPints TwentyPints is offline
Rattle from rear window area
going over bumps i always hear a loose rattle sound.... after closing my door a few times i could tell the rattle was coming from below the rear window (that pannel opposite the box). has anyone else had this problem?
K&N High-Flow Air Filter
Flowmaster 40 Series Muffler (Dual Out)
Vibrant Performance Exhaust Tips
BFGoodrich Mud-Terrain T/A LT265/75R16
Clarion Pro Audio System
Old 04-23-2006, 09:35 AM
mikethehammer's Avatar
mikethehammer mikethehammer is offline
Re: Rattle from rear window area
yeah i have this problem too sometimes, but it seems to be more on the pass side, and sometimes after it rains there are a few water spots on the inside. not sure how to deal with it yet.
Old 04-23-2006, 07:08 PM
im still under warrenty so im gonna bring it in next week i think. this truck has one noise or tick after another.
Old 04-24-2006, 07:04 PM
TexasF355F1's Avatar
TexasF355F1 TexasF355F1 is offline
Send a message via AIM to TexasF355F1
Have that too. I've narrowed the rattle noise to the rear seat - passenger side. The seat is loose somewhere and if you grab the seat top and pull it you recreate the sound. The water I've seen lands on the top of my seat to the right of the passenger side rear headrest. Looked for leaks, but it only happens on occasion.
*Under Construction - New sig to debut*
Old 04-25-2006, 04:17 PM
i am going to try to use clear sillicone on the the third brake light i think it comes from there. i will let ya know
Old 04-25-2006, 06:38 PM
Yea let me know.
Old 03-17-2008, 07:56 AM
xjcamaro89 xjcamaro89 is offline
Sorry to dig up an oldie but what did you guys figure out about the water leak, was it the third brake light or was it the rear window leaking, im going to silicone something tonight, either the brake light or the rear window on mine, thanks!
Old 03-17-2008, 01:29 PM
i still haven't gotten around to it but the water is not really an issue anymore but the rattle is. i have a amp rack that sits on the metal below the rear window and i think it is pushing against the seat making the rattling and squeking. i finally have a garage of my own to work in so i will check it out
Old 03-18-2008, 07:29 AM
Ok, i put a bead of clear silicone in the crack between the rear window and the body across the top and all the way down the sides, we are supposed to get quite a bit of rain today and tommorow and ill see if that fixed my problem.
Old 03-20-2008, 09:00 AM
OK, i silicone sealed the top and sides of the rear window (my window is all one peice) on monday. Tuesday is rained and Wednesday is rained, no water on tuesday, but wednesday i had some on the floor behind the seat. So the only thing left to do was seal the third brake light lens. So last night i pulled it off and low and behold there was water inside the body hole where the third brake light goes! So i put a bead of silicone where the lens should seal to the body and also where the screws go in, so now i just need to wait till it rains again here to see if it worked, if not, i dont know where the water is coming from!
Old 03-22-2008, 12:22 PM
gremlin96 gremlin96 is offline
you could also be getting water in via the cab vents in the back oof the cab between the cab and bed. there two retangles that chevy covers up so the vents do not work any way.
Old 03-24-2008, 07:11 AM
Well my leak is coming in from above the rear window.
