Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 04-22-2006, 10:01 PM
firestarter69 firestarter69 is offline
Angry burning too much oil
I have a 97 gst and the turbo blew so I bought a t3/t4 hybrid. I put it all back together and now it smokes like crazy. Like oil is just being pored into it.
Any ideas? What to look at? I think the o2 sensor is burnt out. Any ideas on wastegate vac hose connections?
Old 04-22-2006, 11:22 PM
blk_srt's Avatar
blk_srt blk_srt is offline
Send a message via AIM to blk_srt Send a message via MSN to blk_srt
Re: burning too much oil
was the turbo new? Sounds like a blown oil seal. Check inside the intake and ic pipes and see if you see oil, also check the oil level and see if and how much its dropped. and what about the wastegate?
2004 Flame Red SRT-4
|Audiobahn 1200Q|Rockford 602s|Jensen flip out dvd|
Mods:
Old 04-23-2006, 03:05 PM
The turbo is new and its not leaking anywhere. The wastegate is a 47mm no name brand. The oil drops alot every time I start it up. I'm paying on 2 cars and can only afford one what do i do?
Old 04-23-2006, 06:15 PM
ez1286's Avatar
ez1286 ez1286 is offline
Send a message via AIM to ez1286
So there is no oil in the turbo? What brand is the turbo? Just as a precaution do a compression test.
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff.
http://www.ratemydsm.com/member/ez1286/?member=ez1286
Old 04-24-2006, 06:41 PM
No idea what brand where do i find that? I'll try the compression test. Thanx
Old 04-24-2006, 06:53 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
You bought a brand new turbo and you don't even know what brand it is? Where did you get it from?
95 Talon TSI AWD
97 Eclipse GST
Old 04-24-2006, 06:59 PM
E-bay If you look at other threads I started you can see the kit.
Old 04-24-2006, 07:15 PM
blk_srt's Avatar
oh yeah thats right, you have an xspower kit. That explains why you are burning oil. I'll put $100 down saying your shaft seal is shot
Mods:
Old 04-24-2006, 07:16 PM
That looks like a pretty cheap/shady kit to me. Where is it smoking from, out the back of the exhaust right? Or the turbo itself it smoking like crazy?
95 Talon TSI AWD
97 Eclipse GST
Old 04-25-2006, 06:11 AM
out the exhaust. But how do I know if its bad? I left the ic pipe off and started it and no oil leaks.
Old 04-25-2006, 06:12 AM
If it is bad how hard is it to fix?
Old 04-25-2006, 11:11 AM
crunchymilk55's Avatar
crunchymilk55 crunchymilk55 is offline
Send a message via AIM to crunchymilk55
It's not worth fixing, your turbo is literally glued together. Lesson learned, don't buy XSPower turbos.....or anything from them IMO
now - 2000 civic
soon - 2002 is300
Old 04-26-2006, 07:22 AM
Then I need a turbo that bolts to a t3 manifold flange for cheap. Any ideas?
Old 04-26-2006, 04:47 PM
blk_srt's Avatar
t3 and cheap dont usually go together unless you get a stocker from something that has the t3 flange
Mods:
Old 04-27-2006, 11:51 PM
Then I should just buy a stock replacement, cause the compression test turned out good.
