Old 04-22-2006, 08:54 PM
BlKQueen_38171 BlKQueen_38171 is offline
I was wondering.........
is there anyway i can get the glue off of the windows, because things got very messy while i was glueing the front and rear windows on my car and now it looks very crappy
Old 04-22-2006, 10:54 PM
freakray freakray is offline
AF Modelrater
Re: I was wondering.........
First question is what kind of glue were you using?
AF User Guidelines
Old 04-22-2006, 11:03 PM
Lownslow's Avatar
Lownslow Lownslow is offline
ive only seen 2 windows restored after testors spilled on to them. and it want easy to do
Old 04-22-2006, 11:10 PM
Un-named member's Avatar
Un-named member Un-named member is offline
Banned
if the window isn't already put in the body shell, it is easy to polish it like you would the body. start with a grit like 2500 and sand the glued up area and then polish it with polishing compound like scratch-x. if you work hard, it will eventually be clear and shiny and like new. it takes some elbow grease, though lolz! if it is already in the body, you can do it but it is more tricky but you can be trickier and succede!
freakray, why did you quote me in your signature? you make me very sad.
Old 04-23-2006, 04:50 AM
RallyRaider's Avatar
Zomby Woof
I was wondering......... if we should unmask the above un-named member? Whatcha reckon willimo?
Old 04-23-2006, 10:12 AM
gionc's Avatar
gionc gionc is offline
Authorized Vendor
Just polish it: I had a bit of extra thin cement (Tamy) on my 250california windshield: now it's invisible. Good luck
gio
Old 04-23-2006, 10:34 PM
Ronfar Ronfar is offline
I usually rub the glue off with a little paint thinner, and then polish off the window.
Old 04-23-2006, 11:01 PM
SteveK2003 SteveK2003 is offline
Send a message via AIM to SteveK2003 Send a message via Yahoo to SteveK2003
If you cannot clean the glue off the windshield well enough, you can just use the kit windows as templates to cut some new windows out of acetate sheet, which will likely look better if you do it right because they are a much more scale width (A real car window should be something like 0.015" thick, about 1/4 of a millimeter: The glass in models would be about an inch thick on a real car).
