Old 04-22-2006, 08:24 PM
94VL 94VL is offline
Post 2nd Generation Trunk/window Leaks
Leaking windows on 2nd Gen J bodies seems to be a common problem once they age....when you see water in the trunk,pretty good chance there is a rusted seam/lip hidden beneath the glass....what are people's experiences with this problem? Have you suffered a leaky trunk? How did you fix it? And is it more common on 2drs than 4 drs?
Old 04-22-2006, 10:17 PM
OverAllComa OverAllComa is offline
Send a message via AIM to OverAllComa
Re: 2nd Generation Trunk/window Leaks
Posted it before, I'll post it again.
Here's how you define "leaky trunk:"
1992 Chevrolet Cavalier Z24 *R.I.P.*
3.1L MPFI (3.1 6cylinder Pushrod 12V)
1997 Chevrolet Cavalier Z24 *R.I.P.*
2.4L "Twin Cam" (2.4 4cylinder DOHC 16V)
2003 Honda Accord EX V6 - The new hotness
Old 04-23-2006, 11:52 AM
Those are obviously wheel well rust areas,not necessarily due to leaking rear windows and trunk seals.What I am discussing is leaks that come from up above,and leak down to the trunk floor/well,turning the spare tire cover into a soaked piece of cardboard.
However,thats the worst bit of wheelwell rusting I have ever seen! I would never have let it get that far without welding in a patch or using the SEM patch panel adhesive in gluing in a new square....
Wow.
Old 04-24-2006, 03:21 AM
You assume I know how to weld...
In fairness, it was sold as-is and the guy that bought it got it repaired in 2 days. Its now owned by another guy from the same car club who's been doing some work on it. Its starting to look like a pretty nice car nowadays.
Old 04-26-2006, 08:01 PM
C'mon people.....there has to be some 2nd gen (1988-1994) J body leaky trunks out there....it seems to be a common problem...both rear window area AND front window area.This is a built in GM design problem...no one is immune from this major flaw.Eventually ALL will leak.
Old 05-16-2006, 08:47 PM
Bump.
Old 05-16-2006, 08:52 PM
From what I can gather,the majority of the leaking takes place within the vertical support between the wheelwell and the underside of the rear window on the driver side.This is a hollow,boxed reinforcement,making it impossible to get into this area to access any leaking.I URGE any and ALL 1988-1994 2-door coupe J Owners to peek into their trunks and raise the spare tire well cover....and check how deep the water is.There has to be a fix for this problem....before the trunk rusts away to nothing.
Old 05-26-2006, 06:35 PM
I read in a GM TSB for Berettas that roof seams that come agap over time leads to leaky trunks.Anyone have this happen with a 2 door J-car?
