Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 04-22-2006, 05:42 PM
Talon69's Avatar
Talon69 Talon69 is offline
Send a message via AIM to Talon69 Send a message via MSN to Talon69 Send a message via Yahoo to Talon69
This 1g Head and intake swap sucks!!! Need some help again
Well now im stuck on the coil pack, where the hell do i mount my coil pack now since it does not fit on the 1g intake like the 2g?
Also with the 1g waterpump pipe installed there is no need for this old water line to the turbo correct?
I just block the water hole off in the block?
Thanx
Eric
Current Cars
2006 Eclipse GT 6 speed MT (V6 3.8), mods so far- S Tech Springs, after market 18's, 2012 headlight Conversion, Greddy cat back exhaust, CAI, RRE Headers, Polyurethane Motor Mounts, NX Nitrous kit at 100 shot for now, RPM Window Switch, Triple Pod.
2003 Grand AM GT - official beater car for the winter lol
95 TSI AWD [email protected] (T-25)
Now fully Modded engine with 3,560 miles on it.SOLD
Old 04-23-2006, 09:45 AM
Talon69's Avatar
Re: This 1g Head and intake swap sucks!!! Need some help again
Do cut all the ears off the coil mounting bracket? Or do i need to relocate my coil pack? What are all you guys doing that have done the 1g intake swap about this?
I have been searching around but cannot find any pictures.
Thanx alot
Current Cars
Old 04-23-2006, 12:57 PM
defiancy's Avatar
defiancy defiancy is offline
Stay classy San Diego
Maybe get a 1g coil pack? would that work? I can't imagine the two being any different other than the mounting situation.
1991 GSX 2.3 Stroker
Old 04-23-2006, 10:16 PM
scottsee scottsee is offline
Send a message via AIM to scottsee
I would like to help you out their, but mouting your coil pack; I'm just not furmilure with how its done. It's in a diffrent location then the 2g, so I can see why your having such a problem.
Just tighten the Banjo bolt into the block. Or use bolt to block it off, that is unless you want to buy a Water Temp gauge..
DSM geek
Old 04-24-2006, 03:37 PM
TTalon's Avatar
TTalon TTalon is offline
you can either use a 1g c/p or just use the mounting bracket from a 1g c/p.
when you say 1g water pipe - is it a n/t pipe ? or 90 turbo pipe ?
1999 Eclipse gs/t
1996 Talon AWD
1991 Talon NT
www.turboeclipse.com
Old 04-24-2006, 05:33 PM
Talon69's Avatar
The pipe is mounted right in the above picture. From a 92 turbo
Alos all the damn people on here that have done a 1g intake swap on there 2g this is all i get for answers lol nothing against you guys that replied im just playing lol its all good Thanx so far for the help
Current Cars
Old 04-25-2006, 12:27 AM
95_GSX's Avatar
95_GSX 95_GSX is offline
Send a message via Yahoo to 95_GSX
I have some pics, but they are all on my camera at my parents house(220 miles away). I have been working for the past 4 days on getting my 6-bolt into my car. I just modified the 2G coil pack bracket to sit in about the same location as the stock set up. I actually cut one end of the bracket off, then bent one tab and it fit like a glove. It will be a while before I could get any pics up though sorry. When I was done, it was perfect. Just get creative with a grinder and cut-off wheel/hack-saw and you should be able to make something work.
Got AWD?
Some people buy super cars, other build them
----Click It, For Mods and Pics----
'95 Mitsubishi Eclipse GSX - For Sale
'05 Volkwagen Golf GLS TDI - My daily driver
'03 Ford Excursion 6.0L PSD 4x4
'13 Ford F150 FX4 SCREW 4x4 3.5L EcoBoost
'08 Buell 1125R
'83 GMC Sierra Classic K2500 4x4 - Future Cummins Swap
Old 04-25-2006, 11:14 AM
crimsin crimsin is offline
go get some msd coil packs, they are better than the stock packs, then mount them on the fire wall. the stock packs are weak anyways
95 AWD
T-28
Dejon/GM maf
Voodoo MBC
MSD DIS 2
550 denso
Walbro 255
Old 04-25-2006, 07:51 PM
Talon69's Avatar
Allright man i will try that this weekend. Its just hard for me to work on my car everyday since its 100 miles from me at my moms house
Than alot
Current Cars
Old 04-25-2006, 09:07 PM
95_GSX's Avatar
Than alot
I know your pain, my car is 220 miles away at my parents house. I was lucky(I guess) and lost a rod when I was there over spring break. Its the only place I have to work on it. It would have sucked balls to have lost it where I go to college.
Looking at your pics, I cut off the end where both tabs point down. Then the other side has both pointing away from the bracket. i bent the tab closest to the intake down and used the tab closest to the head for my mounting point. I was in a hurry so my bracket is only bolted on with one bolt. but its solid and it rocks back against the manni for extra support. It works well, and I think once you look at everything, what I just said will make sense.
Got AWD?
'08 Buell 1125R
Old 05-08-2006, 07:20 PM
95_GSX's Avatar
Sorry it took me so long but here are some pics of how I did my coil set up, just let me know if you have questions.
Here is what I did to the bracket
[IMG][/IMG]
[IMG][/IMG]
The bolt hole towards the bottom of the IM is the one i used
[IMG][/IMG]
here is the bracket bolted in place
[IMG][/IMG]
here is everything installed.
[IMG][/IMG]
Hope these help you a little.
Got AWD?
'08 Buell 1125R
Old 05-08-2006, 09:47 PM
kjewer1 kjewer1 is offline
AF - Advisor
You guys spend way too much time on this. I let my coil pack hang by the wires. I ran like that with stock plug wires deep into the 11s for years. In the end though I mounted it to the firewall to avoid scratching the BJs SMIM, but even that took 10 minutes. I move the break fluid res over and used one of the threaded holes. There are pics on my site.
Block that hole coolant feed off with a replacement bolt and a crush washer, naturally.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 05-09-2006, 06:13 AM
Talon69's Avatar
You mean the hole in the block? hopefully because i allready plugged it.
Current Cars
Old 05-09-2006, 08:12 AM
AF - Advisor
Yeah, block that POS off. The 1gT pipe provides the coolant feed.
Kevin Jewer
