Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 04-22-2006, 05:18 PM
blk_srt's Avatar
blk_srt blk_srt is offline
Send a message via AIM to blk_srt Send a message via MSN to blk_srt
hole in the fire wall
I need to either find or cut a 1.5" hole in the fire wall for my ebc connector to go through and I was wondering if anyone knows where the best place to do this is? Preferably on the passengers side because the control solenoid is on the passenger side shock tower
2004 Flame Red SRT-4
|Audiobahn 1200Q|Rockford 602s|Jensen flip out dvd|
Mods:
Old 04-22-2006, 11:29 PM
blk_srt's Avatar
Re: hole in the fire wall
Mods:
Old 04-22-2006, 11:33 PM
crunchymilk55's Avatar
crunchymilk55 crunchymilk55 is offline
Send a message via AIM to crunchymilk55
your ebc connector is 1.5 inches??
now - 2000 civic
soon - 2002 is300
Old 04-23-2006, 12:24 AM
E-Klips E-Klips is offline
Banned
What you should do is cut the 3 wires that run to the pressure sender and cut the 2 wires that run to the actuator. Then get some heat shrink and solder the wires back together once you get them through the firewall.
This is what I had to do with my AVC-R. No big deal, just snip and rewire. Good as new.
Old 04-23-2006, 11:14 AM
ez1286's Avatar
ez1286 ez1286 is offline
Send a message via AIM to ez1286
Where the engine wire harness goes through. If you take off the rubber thing and the white plastic thing under that it should fit.
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff.
http://www.ratemydsm.com/member/ez1286/?member=ez1286
Old 04-23-2006, 11:17 AM
blk_srt's Avatar
well the connector for the hsk evc is a 7 pin connector instead of a 4 pin and 3 pin. I'm going to try and use an existing gromet on the passengers side and see how that works
EDIT: thanks EZ
Mods:
Old 04-24-2006, 10:22 PM
blk_srt's Avatar
Ok, I got it through and just need to hook up the power wire and I'm done
Mods:
