Old 04-22-2006, 04:09 PM
makaveli3004 makaveli3004 is offline
Adding 2nd battery causes resistance?
Hey i got a kenwood xxc indash which powers my mmats 2100.05 and the jl 13w7. I also got 2 2.4 fahred power caps connected and i have a stinger battery sittin inm y garage. Circuit city said it woudl cause resistance to add the battery. Im not sure if they told the truth or they just didnt want to oinstall it to save time. let me know yoiur thoughts on this
http://members.cardomain.com/makaveli3004 My 97 Camry
Old 04-22-2006, 05:36 PM
germanyt germanyt is offline
Re: Adding 2nd battery causes resistance?
if you mean that you won't get as much power to the amps because there is a battery between them and the main battery that is b/s. as long as the alternator can handle it you could have 15 volts or higher at the rear battery. I have 15 volts at the alt post and 14 at the rear battery. 14 volts suits me just fine.
(2) RE SX 15s (www.reaudio.com)
~6.5^3 net @ 35 Hz (polyfilled to increse vol. & lower tuning to 32 Hz)
(2) eD Nine.1s (www.edesignaudio.com)
1 Optima yellow top (www.optimabatteries.com)
1 Optima red top
200 amp alt (www.dbelectrical.com)
eDead V1SE2 250 sq ft
Big 3 (1/0 awg)
Pioneer DEH-P650 (www.pioneerelectronics.com)
Infinity Reference 5 1/4 comps (www.infinitysystems.com
Infinity Kappa 6x9s
MTX Thunder 3404
Power Acoustik TFT/LCD
Pyle DVD/CD/MP3/WAV/WMA player
Old 04-23-2006, 06:30 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
I think what they were meaning is .... when you add another battery, you are putting another load on the alternator -since the alt has to charge it too. Additionally, if you just parallel them - the lower one will drain the higher one (hi/low volts wise).
Old 04-23-2006, 07:05 PM
CBFryman's Avatar
CBFryman CBFryman is offline
Banned
Send a message via AIM to CBFryman Send a message via Yahoo to CBFryman
Never mix brands or types or modles of batteries unless you use an isolator.
just to add to what paul said
Old 04-24-2006, 12:29 PM
Yeah i had a battery isolatoer connected but circiut city took it out now i gotta redo it.
Old 04-24-2006, 12:46 PM
ngsm13's Avatar
ngsm13 ngsm13 is offline
Send a message via AIM to ngsm13
That sucks.
I work @CC, you should come to mine... I'll hook you up. Also, I'm not a retard... as what it sounds your local one is like. haha.
nG
I design custom enclosures!
And...my sig is short!
Oh and.. YOU suck balls...
