Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 04-22-2006, 03:33 PM
nphilly nphilly is offline
what do u think
Do you think I should use block seal to stop my head gasket from leaking? And if so what's the best kind to get? Or will it even work? I only want to use it a s a temp stop. For like 2 months atleast.
Old 04-22-2006, 04:43 PM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: what do u think
Bars has one that would be the best to use but if the gasket is already leaking badly it probably won't work. The best thing to do would be to replace the head gasket.
Old 05-16-2006, 09:48 PM
MrPipes MrPipes is offline
Re: what do u think
best thing to do is to change your head gasket...you can do it in one day and the gasket is just a little more than the stop leak...last thing you wantto do is run out of coolant and blow the engine...a good weekend and some beer will do the trick to fix it...if ya change one...may as well change both...only thing that takes time is taking off the upper plenum and manifolds...make sure you have the hanyes manual for loosening and tightening sequence as well as torque spec's
