Go Back   Automotive Forums Car Chat > Buick > Grand National/GNX
Old 04-22-2006, 02:31 PM
fred robles fred robles is offline
Post myelectric brake system malfunction?!!help
the brakes on my 87 biuck gn were working fine till about 2 weeks ago.The brake light came on and the brake pedal got really hard.All the fuses are ok,the electric motor was rebuilt,the car dose not use vacum on th brakes ,can u help?
Old 04-22-2006, 02:54 PM
edbrycem edbrycem is offline
Re: myelectric brake system malfunction?!!help
are u sure its not vaccuum? on mine if i wre to hit the bakes hard the car almost wants to kill cuz of the vaccuum. I know they made some cheezy concauction for the brakes kinda like a "trial n'error "for ABS but obviously didn't work, and i believe there was a recall on them. If it is vaccuum, check the brake booster on the firewall and make sure the the bigger hose is hooked up and/or not leaking vaccuum. Sorry if this doesn't help, but i hope it does
Old 04-23-2006, 09:16 AM
87 GRANNY 87 GRANNY is offline
For some reason your powermaster brake system is not producing enough boost pressure and not turning off the red lamp. You fist should determine if your pump/motor is running so that can determine if you have a electrical or hydraulic problem. If the pump is runnig all the time see if the pump will produde 600psi at the pump outlet (it should). If pump does not run check the switch/motor for problems. Be careful and always deplete the pressure before opening the hydralic components.
