Old 04-22-2006, 01:59 PM
warmapplecobbler's Avatar
warmapplecobbler warmapplecobbler is offline
Send a message via AIM to warmapplecobbler
Exclamation Leaking Coolant
yesterday i was driving my 88 5.0L trans am on the highway and my temperature started rising and my car started smoking. i pulled over and found coolant all over my engine and the inside of my hood. i found that under the intake manifold there is a small u shaped hose that apparently carries coolant. well that hose had a giant rip in it and i have been calling all over the place and even went to a gm dealership and nobody seems to have that part. if anybody knows what the crap im talking about and knows where i can pick up one of those hoses pleeeeeeeaaasssssseeeeee let me know. Thank you
Old 04-23-2006, 03:01 PM
knight7's Avatar
knight7 knight7 is offline
Send a message via AIM to knight7
Re: Leaking Coolant
just go to autozone and they will give u one. All hoses are made of rubber and can be purchased anywhere. You need to tell autozone the length you need and they will give u one.
If s0methin(g) matt3rz th3n itz da stuff dat iz und3r da ( h00d).
99' firebird 3.8 v6
Old 04-23-2006, 04:48 PM
skibum1111 skibum1111 is offline
Send a message via AIM to skibum1111 Send a message via Yahoo to skibum1111
Re: Leaking Coolant
Take the old one in with you, they might have a miscellaneous prebent hose that will fit.
Rusting out Honda Civic $900
Fart cannon muffler: $300
Assorted stickers advertising products you'll never own: $50
Having your @ss handed to you by a brick shaped suv: Priceless.
Yup, I own the suv.
Old 04-23-2006, 05:00 PM
DarkblueTA's Avatar
DarkblueTA DarkblueTA is offline
Send a message via AIM to DarkblueTA
Re: Leaking Coolant
That or just have them get you the same sized hose and put it on yourself.
DarkblueTA
GT70, FMIC, Alky-water injection, Hooker Cat back, 208/230 .549/.579 121LSA Cam, forged diamond pistons/eagle rods, LS6 block, Lakewood LCAs, BMR STB/PHRB/Sway Bars, poly torque arm bushing, Spec Stage 4i clutch, B&M Ripper Shifter, SLP Subframes, 60# injectors, KYB AGX shocks/struts, Moser 12 bolt(373 gears, 33 spline axles, posi, ta girdle/etc/etc/etc) and HPTuner kit
2007 Nissan Titan Daily Driver. 2* advance
Old 04-23-2006, 08:54 PM
83T/A98Blazer 83T/A98Blazer is offline
Re: Leaking Coolant
Those small hoses will kink if you just use bulk hose cut to length. I have one like that on my 83 and had to order it from a dealer. They may not make them anymore. I have a GM parts manual, is that hose on the front or rear of the intake?
Edit: In the parts manual there is a u-shaped coolant hose called a throttle body heater hose on the front of the intake. If that is the right hose the GM part number is 10108509. Sometimes they will be able to locate one with the old part number. Hope that helps.
Old 04-25-2006, 01:53 PM
Re: Leaking Coolant
thanks guys...but i guess i asked for help to soon cuz it was a really easy fix. i had to use a cut to fit hose but i was looking for the exact shape hose the whole time. thanks for your advise though everyone
Old 04-25-2006, 09:26 PM
Live702's Avatar
Live702 Live702 is offline
Re: Leaking Coolant
I also had to replace that hose, and a non molded one does not fit, it kinks up really bad. I took it to autozone and they were able to find one that matched, and I cut it to size.
- 1989 Trans Am GTA
