Old 04-22-2006, 12:26 PM
Bern23 Bern23 is offline
Advice needed
My '88 Grand Prix recently wouldn't start on the morning. I thought it was the battery so i put i charger on it, but when I tried 4 hrs later the same thing was happening it didn't want to turn over at all. I took the battery and had it tested and there was a charge in it. And I know it can't be the Alternator because I replaced that in Oct. I'm possible thinking that its either the cyclinoid or the starter. Does anyone else has any suggestions? Thanks
Old 04-22-2006, 04:49 PM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: Advice needed
Did you hear the solenoid trying to click in when you turned the key. If not then that is where I would start. There are four possibilities, 1-bad solenoid, 2-bad starter, 3-bad ignition switch and 4-bad wiring to the starter or corroded wiring from the battery terminals to the starter or ground. Try the wiring first and clean everything and make sure you have good grounds. Then go from there.
Good Luck and Welcome to AF!!
Old 04-22-2006, 07:40 PM
wlkjr's Avatar
wlkjr wlkjr is offline
Re: Advice needed
Do these things still have a fuse link?
97 Grand Prix GT
360,000 miles as of 02-01-09
391 000 miles as of 11-17-11
400,000 miles as of 3-15-13
01 Duramax/Allison
07 G6 convertible
Old 04-23-2006, 09:47 AM
Pontiac Guy
Re: Advice needed
Yes they do and they should be located at the starter, so checking the starter wiring should find the problem if the fusable link is bad.
Old 04-23-2006, 10:28 AM
99`_grand_am 99`_grand_am is offline
Send a message via AIM to 99`_grand_am
Re: Advice needed
check that.... belt thing that needs to be changed sometimes, shit, i had to do it in my old prix, the car would just make noise but it would never start.. i don't know just a thought
Old 04-24-2006, 10:11 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: Advice needed
when you had the battery tested, did they load test it? A battery can show voltage, but not have enough amperage to turn the starter. If the battery checks out, the next thing you need to check is if you have voltage at the "s" terminal of the starter when the key is turned to the start position. If you have voltage, then the starter or solenoid is bad. If no voltage at the "s" terminal with the key in the start position, you have a bad neutral safety switch or ignition switch.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
