Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 04-22-2006, 12:22 PM
ddax's Avatar
ddax ddax is offline
Grilles - which years fit
Anyone know when (if any) changes were made to the Caprice grilles from 77 through 90? Which would fit an '83?
Dave
Old 04-22-2006, 01:48 PM
BZR77CHEVY BZR77CHEVY is offline
Re: Grilles - which years fit
77-79 are different (shorter) than the 80-85, changing again in 86 & 87, and i think again 88-90. Therefore I think the 80-85 will fit your application.
Old 04-22-2006, 02:15 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
The BIG changes are '77-79, '80-85 and '86-90. The '86-90 grille is the same, but is smaller than the '80-85. There were some asthetic changes in the '80-85 model years - the only one that I know stands out is the '80 which will fit any of those 6 years. I thought of that particular group, the '80 was the best looking.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 04-22-2006, 02:49 PM
Also, the 80's top trim matches the top of headlight surround.
Old 04-22-2006, 04:16 PM
GreyGoose006 GreyGoose006 is offline
in 84 the grille was a seperate piece that came off by its self. on some later models afer 85, i believe that the whole front clip was one piece. the later ones used one big headlight instead of two on each side.
