Old 04-22-2006, 11:58 AM
grandprix00 grandprix00 is offline
Post Gt supercharger
Hey i was wondering is there any diffrence of a 97 gtp engie that i could take the heads intake and supercharger off and put them on at gt 00 my buddie did it but he doesnt know if there is any diffrence in thous years
Old 04-22-2006, 04:55 PM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: Gt supercharger
The GT and GTP short blocks are the same but that is where the similarities end. The GTP-L67 engine has different heads and a lower compression ratio than the L-36 engine. To do this installation you need a new fuel pump, transmission, axle shafts, wiring harness, PCM, supercharger, fuel rail and fuel injectors from the supercharged engine. You would also need the pulley set up from the supercharged engine. It is complicated and can be expensive. You would be better off putting a turbo on the car.
Old 04-22-2006, 10:58 PM
Re: Gt supercharger
Well cant i just do the intake fuel rails heads supercharger and fuel pump? not the tranny?
Old 04-23-2006, 09:34 AM
Pontiac Guy
Re: Gt supercharger
The tranny currently in the car will not hold up to the extra horsepower of the supercharger. Although you can do the change over and use the tranny you have until you destroy it and then put a heavy duty tranny in the car.
Old 04-23-2006, 11:36 AM
Re: Gt supercharger
thats what i was going to do my car only has 40,000 miles on it i think it should last until 60k wouldnt u say
Old 04-23-2006, 11:47 AM
Re: Gt supercharger
Oh yeah another ? im looking at gtp engine thats a 97 will it work with parts for my 00?
Old 04-23-2006, 01:53 PM
Pontiac Guy
Re: Gt supercharger
The engines should be the same although the PCM's from the early 97's will not interchange with the later models. There are some vacuum ports on the 97 supercharger that are not on the newer models either but that shouldn't be an issue.
