Go Back   Automotive Forums Car Chat > Buick > Skylark
Old 04-22-2006, 04:09 AM
XeroBlade XeroBlade is offline
Exclamation 1991 skylark, Wide open idle problem
Hello all you nice people out there. Maybe someone could help me. My skylark 2.5L Throttle body injection, has a big problem. I start the car and it does something as i could only describe as a very high idle. It sould like if you put the car in park and step on the gas a bit. it revs up really high high rpms. Now i checked it the gas pedal line was stuck but theres slack at the throttle body and the butterfly is mostly closed, I can rev the car still too. Now all this high idling causes the car to over heat quickly, like 5 mins which caused a line to break. What could cause the high idle, the throttle postition sensor or the wide open idle cut off sensor. Any ideas out there.
Old 04-24-2006, 09:21 PM
tomogchi tomogchi is offline
Send a message via AIM to tomogchi Send a message via MSN to tomogchi
Re: 1991 skylark, Wide open idle problem
Is your tps actually saying its closed???? I'd check it with a Dvom.
and if you hit the gas, does the idle drop at all?
Bill
