Old 04-21-2006, 09:14 PM
Camaro84 Camaro84 is offline
Car wont idel???????????
My car isnt goin into its normal fast idel when i start it up cold......
i have to hold the gas down a little bit while it runs really rough......
Then little by little it goes into a faster idel and then i can tap it to go into its normal idel after it warms up a little bit........ and then it runs great!!!!
what could be wrong??????????
Old 04-21-2006, 09:31 PM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
Re: Car wont idel???????????
choke!
bare minimal chance it could be curb idle speed
Old 04-21-2006, 09:34 PM
The choke opens just alittle bit is that normall........
what could be wrong with the choke?????????????
Old 04-21-2006, 09:43 PM
wrightz28's Avatar
cold the choke plate s/b closed, the after normally 2 min max. it s/b wide open
Old 04-21-2006, 10:00 PM
Yeah afetr a couple mins it opens all the way............
Old 04-21-2006, 10:03 PM
wrightz28's Avatar
dude, you just said it opens a little way, what gives?
Old 04-21-2006, 11:08 PM
when i first start it, it opens just a little bit....... and has it warms up it opens all the way..............
Old 04-22-2006, 12:27 PM
thats not the problem......
its not jumping into the high idel when i first start it.............
Old 04-22-2006, 01:03 PM
92zcamaroperson's Avatar
92zcamaroperson 92zcamaroperson is offline
how much vacuum does your motor have and what is your timing at?
92 z28 camaro 5.7 TPI
current - slp intake runners and base-BBK 52mm throttle body-MSD 8.5mm wires, blaster coil, and 6AL Box-edelbrock headers-160 degree stat.-hotchkis strut tower brace
waiting in the garage - LQ4, milled heads 317 casting (10.5 to 1), hardened pushrods, ported LS6 oil pump, manley dual spings with titanium retainers, MTI X1 cam, hawks longtube headers
Old 04-22-2006, 03:17 PM
I dont even know to both of those questions
Old 04-22-2006, 03:38 PM
my timing is past the 12 mark if there was like a 16 or an 18 thats were it would be.............. we tried to get it closer to 0 but it seems like the closer it got the car would run even worse.................
Old 04-22-2006, 05:34 PM
i would definetly look into the vacuum system. I assume you have a vacuum advance right?
Old 04-22-2006, 07:13 PM
IO dont even noe what the vacuumm advance is
Old 04-24-2006, 08:43 AM
wrightz28's Avatar
What is controlling your distributers advance curve, electirc or vacuum is what it means.
Old 04-24-2006, 09:44 AM
if you go to just about any parts store you can get a cheap vacuum guage. Even some boost guages will show vaccuum. Anything that will measure negative pressure. Hook the guage up to one of the vaccum ports on the carb and see what it reads.
