Old 04-21-2006, 07:54 PM
Oldbridge123 Oldbridge123 is offline
Annoying Noise!!!
Hey how are you 3gt owners my name is Dave and I own a 1992 3000gt VR4 with 98,000 miles. I've had it for 2 years now and all I can say is amazing, this is a classic in my opinion but that's besides the point. I have a few question's and i would appreciate if i get can get some response to them. Recently my car started making this SCREECHING sor of wistling type of noise, my mechanic said it was the pulleys so i purchased the 3 main pulleys on the 3sxperfomace.com they were the 2 Tensioners, and 1 Idler, but i keep on heraing the same noise when my car is moving. It starts screeching when i go over 20mph but quiets before that. I was wondering if anyone had that same problem.
Old 04-21-2006, 08:08 PM
VR43000GT's Avatar
VR43000GT VR43000GT is offline
Send a message via AIM to VR43000GT
Re: Annoying Noise!!!
Does it matter what rpms your are at? It sounds like maybe a belt. Otherwise all I can think of is the rotor rubbing agianst the pads or a wheel bearing.
Old 04-22-2006, 02:58 AM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
can you give us more details, please.
as SL3000GT said, does engine RPM seem to play a factor?
i assume you hear the noise coming from the engine bay?
does the sound occur when the car is under load? cruising? decelerating? or just all time over 20mph?
can you describe to us the screeching sound? is it like a whine or rather a chalk-board like screech?
prematurely, to me it sounds like your alternator is going out. with the sound occuring only at speeds over 20 mph, it would make sense that you alternator is having trouble keeping everything recharged at that certain level of strain on the vehicle. i could be way off, and its a premature diagnosis.
let us know more about it.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 04-22-2006, 03:15 PM
Igovert500's Avatar
blue + red light magnet
Yeah, the more info the better.
When you swapped pulleys, did you change the belts?
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 04-23-2006, 03:18 AM
mehrshadvr4 mehrshadvr4 is offline
i had a problem when i bout my car.the AC compresor was always locked even when the AC was off.unplug the AC to see if it makes that nice again,bu that would be better if you give us more info.
