Old 04-21-2006, 04:08 PM
01L2Cobra's Avatar
01L2Cobra 01L2Cobra is offline
GT500 Engine Failures already?
Yep the GT 500 already has major failure issues. It seems that the crank shaft has been fracturing or breaking at the snout. It’s a good thing this was caught early unlike the issues the GT had that ended with them having to install a diaper.
http://www.blueovalnews.com/index.ph..._articleid=237
The ///M stands for Motorsports
Old 04-21-2006, 05:13 PM
SVTcobra306's Avatar
SVTcobra306 SVTcobra306 is offline
Re: GT500 Engine Failures already?
TROLL!
1994 SVT Cobra. 306, Ported GT-40X's, Crane 2031, NX Wet Kit (100 shot for now),TKO 500, TwEECer R/T, and all the bolt-ons.....
http://www.cardomain.com/id/mccobra94
1995 F-150 SC/4X4 351W/E4OD, K&N, Custom Exhaust w/Flowmaster.
Freedom Isn't Free.
Old 04-22-2006, 12:18 AM
speedfreak's Avatar
speedfreak speedfreak is offline
Send a message via AIM to speedfreak Send a message via MSN to speedfreak
The fact that this same problem is happening again on what is essentially the same engine as the GT is the problem. However, even BON presents the article as unsubstantiated.
A 26lb damper? What are they, stupid?
1968 Mustang notchback Roller 302, Edelbrocks, Hookers, side-exits, RRs, Crane 2031, Duraspark, forged slugs, X-Celerator, 650DP, Fidanza FW, RAM clutch, Toploader, Comp Plus, McLeod bell, 15x7s, 1 1/8 swaybar.
1972 Ford Pinto SVO 2.3 turbo, MegaSquirt, T5, 8", etc.
'95 Honda XR600-10.5:1, 628cc, ported head, & more.
Old 04-22-2006, 03:46 PM
01L2Cobra's Avatar
No they are smart its how they got them to pass emissions. With less than 26lbs it revs to fast and won’t pass the emissions standards.
Old 04-22-2006, 04:28 PM
speedfreak's Avatar
Eh, that doesn't make a lot of sense to me, but thats fine if it's the case. I reread the article and it said the GT uses something similar.......which goes back to what I said about how this should have already been sorted out.
Old 04-23-2006, 11:42 AM
01L2Cobra's Avatar
the one on the GT is less than 1/2 the weight of the one used on the GT500
Old 04-23-2006, 01:50 PM
speedfreak's Avatar
Old 04-23-2006, 07:54 PM
TheStang00's Avatar
TheStang00 TheStang00 is offline
hes right, if you read the peice speedfreak posted it says the Lightnings balancer is less than half the weight.
Old 04-24-2006, 12:23 AM
01L2Cobra's Avatar
From the paragraph before that
Originally Posted by BON
Ford designed a crankshaft damper specifically for the GT500
The one that was on the GT was less than half the weight as the one on the GT500 and was specifically designed for GT.
Old 04-24-2006, 01:44 AM
speedfreak's Avatar
Ok, it doesn't say that anywhere.
Old 04-24-2006, 08:53 AM
01L2Cobra's Avatar
Its in the 2nd paragraph in the link I posted
Old 04-24-2006, 02:34 PM
speedfreak's Avatar
Originally Posted by Blue Oval News
Sources close to the 2007 Shelby GT500 program are alleging that the crankshafts in the 5.4L GT500 engines are fracturing or breaking at the snout (nose) where the engine damper rides. The sources are alleging that the GT500 crankshaft breakage can be attributed to two complimentary issues. According to our reliable sources, Ford designed a crankshaft damper specifically for the GT500, but the damper weighs in at a hefty 26 pounds.
This is the second paragraph and it says nothing about the GT's damper nor how much it weighs. It just says that the GT500 got a damper designed just for it. That could mean anything, like its almost identical to the GT's, but the diameter is different or the pully configuration is changed, but they weigh the same. I'm done with this, it doesn't even matter at this point other than crank failures shouldn't have been a problem.
Old 04-24-2006, 03:52 PM
01L2Cobra's Avatar
The problem with the GT wasn't the damper because it used one designed for it and it didn't weigh 26lbs. The problem was a oil leak that Ford opted to fix using a speedi-sleeve to stop the leak. The oil leak was due to a random worker who incorrectly polished the cranks with an emory cloth--instead of keeping his hand in the same place while the crank revolved, he moved it down the length in effect creating a path for the oil to follow out of the engine.
Old 04-24-2006, 08:18 PM
TheStang00's Avatar
christ talk about random. im not sure if you can blame ford for that or not...
