Old 04-21-2006, 12:51 PM
puppy2 puppy2 is offline
power windows, need help~!~~
Ok, The windows in my 98 TA seem to have a mind of their own. Ive replaced both the motor and driver side power switch. I still cant get the windows to move when i want them too. What am i missing out on here???
Old 04-21-2006, 12:55 PM
doodad's Avatar
doodad doodad is offline
Send a message via AIM to doodad Send a message via Yahoo to doodad
Re: power windows, need help~!~~
how about your regulator?? is it good??
Old 04-21-2006, 03:17 PM
gmack221's Avatar
gmack221 gmack221 is offline
Are they getting power? (Relay in fuse pannel)
Old 04-22-2006, 01:03 AM
relay??? well the fuse is good, its the same as the power seats. so i switched them around...seat still works. how i check the regulator, where is it located? inside the door around the motor?
Old 04-23-2006, 12:08 PM
unreal.......i found the problem. so simple,yet these monkeys that make the technical manuals forget to mention it. There is a plastic molding where the hood latch release is at. remove it and right in front is a nice shiny 1/2 nut that has the 2 black ground wires for the windows. all the vibration over the years ive had the car had loosen it, i cant believe that was the simplest of solutions. Although with a new motor, the window does move alot faster. So it was a learning experience. maybe this will help others out that might have the same problems with power windows.
Old 04-23-2006, 05:04 PM
DarkblueTA's Avatar
DarkblueTA DarkblueTA is offline
Send a message via AIM to DarkblueTA
Good catch! We need more people like you on the board! Did you have a drill to get the rivets out? GOD I hate that part.
DarkblueTA
GT70, FMIC, Alky-water injection, Hooker Cat back, 208/230 .549/.579 121LSA Cam, forged diamond pistons/eagle rods, LS6 block, Lakewood LCAs, BMR STB/PHRB/Sway Bars, poly torque arm bushing, Spec Stage 4i clutch, B&M Ripper Shifter, SLP Subframes, 60# injectors, KYB AGX shocks/struts, Moser 12 bolt(373 gears, 33 spline axles, posi, ta girdle/etc/etc/etc) and HPTuner kit
2007 Nissan Titan Daily Driver. 2* advance
Old 04-23-2006, 05:58 PM
Mr. Luos's Avatar
Mr. Luos Mr. Luos is offline
Firebird Guy
Hey...I grounded my gauges out there.
Nice catch for sure!! Glad it is better.
This is something I am just waiting to have to do.
1999 Pontiac Trans Am WS.6 #1747
Stock'ish'
Old 04-24-2006, 08:00 AM
superducky55 superducky55 is offline
Im just waiting for it as well ...
My window motors, like all 4gens, are so damned slow.
I'm starting to think about putting one of the last year fbird window motors in (probably will take fabrication) to speed em up
ugh thats a lot of work, though
haha
BTW That ground you speak of, I just grounded my satellite radio there Thats a convenient ass place for gm to stick a ground.
Old 04-24-2006, 09:34 AM
doodad's Avatar
before l replaced mines, mines were soo slow (dying) but now, they are so fast.. about drilling?? I LOVE THAT PART.. the only thing that l hate is putting the door panel back.. but right know in 15mins, l can replace window motor, it is so easy to me anymore..
Old 04-24-2006, 09:41 AM
gmack221's Avatar
If you do it in 15 mins then you take the easy way and drill thru the door to get to the motor rivets. I will never drill thru my door, I drill the mounting rivets out of the door & replace them with bolts so I can take the whole motor assembly out, takes a little longer but I don't like the idea of drilling thru my door. Just like everything else, its worth a little more time to do it right.
Old 04-24-2006, 10:25 AM
Any of yall live near MI and willing to do mine for 50 bucks or somethin?
Old 04-25-2006, 10:49 AM
Yes i did drill through the door panel and drill out the rivets. I took a larger drill bit and it was nothing to shred the end of the rivets. I had a smaller bit that was like drilling dead center of the rivet and it wouldnt do anything to it. So, i wised up and used the larger bit, no problem. Ya, i didnt care for drilling through the panel but i used a small hand file to make the holes nice and neat. After a min. of thinking i had a 2 part epoxy that you mix. 1 is black, the other is gray...so when you mix it..its like a dark or light gray depends on how much you use. but anyways i mixed that up and covered my holes up. the stuff is like concrete, after it dried i sanded smooth. Of course no one in the world is goin to see this but me, just nice knowing i didnt do a sloppy job.
