Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 04-21-2006, 09:30 AM
Chromedubs165db Chromedubs165db is offline
No Clutch!!!
First off thank you for any help in advance!!! I have a 97 passport and it has sat for a bout 2-3 weeks, when I went to run it the clutch pushed down and felt normal but does not disenguage. I changed the slave cyl and still same thing. Any help would be appreciated. By the way I had the clutch changed about a year ago to a six puck HD clutch and at the same time had my flywheel resurfaced.
Old 04-27-2006, 04:24 PM
85crxzc 85crxzc is offline
Send a message via AIM to 85crxzc Send a message via MSN to 85crxzc Send a message via Yahoo to 85crxzc
Re: No Clutch!!!
mmm i had that problem in my crx ...but it was a stock clutch plate and it was cable... took it out and i found that 1 of the springs from the cluth broke and was lodged inbetween the flywheel and pressure plate... funny part is my car was normal and all till i went to the car wash and washed the engine off couldnt see that that has anything to do with it but it really sucked lol
85 crx si spun rod bearing..getting new block
2003 dodge neon se ..family car
