Go Back   Automotive Forums Car Chat > Audi > A4 | S4 | RS4 | A5 > '94 - '01
Old 04-21-2006, 07:05 AM
cas4067 cas4067 is offline
A couple of quick questions
I need to get the bumper painted for my 01 audi a4 and I can't find the tag with the color code on it. Where is it hidden. Also my gas cover sayes 91 premium gas only is that the only things I should put in. And finally what kind of oil should I be running in this car, I put 5w30 is that good??
check it out let me know what you think
my ride
Old 04-24-2006, 08:30 AM
marked001's Avatar
marked001 marked001 is offline
Moderadur
Send a message via AIM to marked001
Re: A couple of quick questions
pretty sure its in the door jamb? if not...look under the spare tire.
SOLD!
Old 04-26-2006, 12:46 AM
tmaster1187 tmaster1187 is offline
Send a message via Yahoo to tmaster1187
Mid grade will work smoothly. Any lower and you MIGHT get pinging. ( spark knock) but maybe not. Depends on what has been used majority of the time.
Old 04-26-2006, 03:16 AM
MikeLee2484 MikeLee2484 is offline
im going to say only use the grade of gas that is recommended. dont use a lower or higher grade than what it says. the reason for this is that cars are designed to run with a certain grade of gas. if you use lower grade, you wont get the performance you should get, and if you use a higher grade nothing will happen except money leaving your wallet when it doesnt have to. like i said, cars are designed to run on a certain grade, and so you wont get the performance or gas mileage you would like out of your car when you use a lower grade. and, like what was said before, if you use a much lower grade gas, there is a chance that you can cause some damage. so just use the 91, youll be happier in the end. and besides, what advantage does audi get if you have to put 91 in your tank? they arent getting more money because of it, there is no conspiracy with the oil/gas companies. and for the oil, there should be a guide in the manual of the car that tells you what oil to use in what weather conditions, just follow that.
Old 05-12-2006, 12:11 PM
Tonto Kowalski Tonto Kowalski is offline
That's not true, in most cases a higher grade will result in better acceleration and will let you go further on a tank of gas.
