Old 04-20-2006, 08:25 PM
StillGoin5.0 StillGoin5.0 is offline
Send a message via AIM to StillGoin5.0
lower ball joints
my passenger side ball joint is shot so i orderd new front control arm assemblies from jegs and i noticed that the ball joint doesn't have a grease fitting. i was wondering if i could just drill and tap a grease fitting on them or does it not have one for a reason?
87 5.0 5 spd T-Tops - mass air conversion 9AL, msd distributer, coil, fms 9mm wires, bbk ceramic coated long tubes, bbk h pipe, 3" flowmaster catback, 190 lph fuel pump, 24 psi injectors, 70mm cobra meter, bbk AFPR, bbk fender kit with k&n filter, 12* base timing, flex fan, 3 row aluminum radiator, 6 piece headlight kit w/ clear corners, silver ponys, stormin normin cowl hood, saleen wing, and recently a new heater core
Old 04-21-2006, 08:11 PM
351wStang's Avatar
351wStang 351wStang is offline
Re: lower ball joints
If it doesnt have a zerk fiting then it must not need one. It wouldnt do any good to drill and tap it.
1969 Cougar
357w & TKO - 475hp
Old 04-22-2006, 12:27 PM
ok thank you for the response..
