Go Back   Automotive Forums Car Chat > Pontiac > Sunfire > General Discussions
Old 04-20-2006, 04:57 PM
mega8man's Avatar
mega8man mega8man is offline
1999 2.2 sfi electrical problem
My sunfire has a very weird problem. here is the story.
I changed the starter and it was working fine for awhile but then the battery died and it wouldnt charge so now i changed the alternator and the battery and also checked all the fuses and now the battery still wont stay charged. i cant figure it out if anyone has any idead please let me know.
Old 04-20-2006, 05:33 PM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: 1999 2.2 sfi electrical problem
You need to replace the battery. The alternator will only maintain a battery not recharge one. You may save the battery if you recharge it with a charger and see what happens. If it fails to hold a charge after that replace the battery with a new one.
Welcome to AF!!
Old 04-20-2006, 05:49 PM
mega8man's Avatar
i dont know if you saw but i wrote that i have already replaced the battery and the alternator...
Old 04-21-2006, 06:39 AM
Pontiac Guy
Sorry, missed that part! Check the wiring to the battery and the alternator for corrosion. This will stop the battery from receiving the charge. Also get a volt meter and see what voltage you are getting when the car is running, should be at least 14. If not then the alternator is not working properly. Also just FYI, new batteries can be bad. I went through three one time before I got a good one.
Old 04-21-2006, 10:11 AM
ThePrairieProphet ThePrairieProphet is offline
Send a message via MSN to ThePrairieProphet Send a message via Yahoo to ThePrairieProphet
so can alternators, as i recently found. if you check my alternator thread from a few days back, my story's listed in there. take your car to autozone (u.s) or part source (canada), they should be able to test it and figure out if the battery is taking charge. possible problems could be a bunk battery, or alternator (even though they're new), and corroded posts on your battery connectors AND grounds.
Do you have anything else wired to your battery (ie stereo amplification, etc.)? I believe that might have been part of my problem, as I replaced the alternator a second time and removed my subwoofer system, no problems since. If none of these things are the problem, pretty much the only other thing it could be is a bad wire or something.
disclaimer ~ my problem was with a 97 2.4, though i would imagine the charging system is similar. hope this helps.
What the hell does rant mean?
www.stillseed.com
