Old 04-20-2006, 03:15 PM
procrstinator procrstinator is offline
fuel pump
ive dropped the fuel tank and now have the pump houseing hanging .how in the hell do you get the pump disconnected from houseing? help please
Old 04-20-2006, 06:18 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: fuel pump
What do you mean by disconnected? Do you mean removing the fuel pressure and return lines or what?
Timeslip 08/12/06
AF Community Guidelines
Old 04-21-2006, 04:25 PM
Re: fuel pump
I Mean How Do I Get The Fuel Pump Out Of The Houseing?
Old 04-21-2006, 04:44 PM
BNaylor's Avatar
Re: fuel pump
Off the fuel tank or out of the fuel pump pod housing? Do you have the whole pump assembly pulled out of the gas tank?
Timeslip 08/12/06
Old 04-21-2006, 06:45 PM
Re: fuel pump
yes i have the pump pod or encloser out of tank
Old 04-21-2006, 07:35 PM
BNaylor's Avatar
Re: fuel pump
Why do you want to remove the pump itself? Normally you just replace the whole pod. Are you planning on putting in an aftermarket pump or I believe there is an AC Delco pump repair kit available.
I've never had one dismantled with the exception of the float and level sending unit. If you take it apart be careful not to break anything because that plastic has deteriorated from the fuel.
Timeslip 08/12/06
Old 04-22-2006, 12:16 AM
Re: fuel pump
yes i was going to change just the pump and i thought you might know how to get it out of pod...is what i see in pitcher what i would get if i get pod .without the fuel filter of coarse
