Old 07-16-2002, 10:43 AM
Xplosive_Sheep Xplosive_Sheep is offline
Send a message via AIM to Xplosive_Sheep
how much power...
how much power can my puny stock alternator put out? its a brand new 2002, and i want to put the biggest amp in there without draining my battery
2002 Honda Civic Sedan LX, manual, apline head CDA 7893...more stuff to come
Old 07-16-2002, 02:07 PM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
imma take a guess at this and say its about 85amps.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 07-16-2002, 04:14 PM
you mean watts? damn, screw that im going for 500 :P
Old 07-16-2002, 06:57 PM
91AcrdMan's Avatar
91AcrdMan 91AcrdMan is offline
Send a message via AIM to 91AcrdMan Send a message via Yahoo to 91AcrdMan
nope he ment amps... and you can get rewound ones that put out like 130amps
Purehonda Member Since June 2000
Red Dime Audio & Engine Swaps!
~Objects in mirror are reflections of those tasting defeat~
Old 07-16-2002, 07:01 PM
Pennzoil GT-R's Avatar
Pennzoil GT-R Pennzoil GT-R is offline
if ya wanna know how much power u will get out from 85amps then use:
Power (Watts) =Voltage (Volts) x Current (Amps)
Old 07-16-2002, 08:06 PM
so how do i figure out how many volts my car can handle so that i can figure out how many amps i can have ??????
Old 07-16-2002, 08:44 PM
well thats where you need a voltmeter, unless it says the output on it somewhere. Unless you can measure it then youre gonna get all confused in a mass of sums that are gonna end up with you needing to measure something in the end anyway
Old 07-16-2002, 09:28 PM
daaaaang, im way to lazy to do all this work, i think that at 450watt amp should do just nicely, my bro has had one for a long time and it hasnt drained his battery, wish me luck
Old 07-16-2002, 09:36 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
well, that gives you the absolute power ........... 14 volts X 85 amps = 1190 watts. But amps are not a static load like say headlight. The power an amp pulls is more in pulses ......... but a 1000 watt RMS amp only pulls only like 100-200 watts of average power. You should be able to run 1200-1500 watts of power with no problem.
Old 07-16-2002, 09:56 PM
colechaney colechaney is offline
Send a message via ICQ to colechaney
It won't drain your battery. Your headlights will just dim whenever the bass hits, it might drop your rpm's a lil too, but not enough to stall you or anything. To fix the problem just get a capacator or two. They sell Rockford-Fosgate 1 farad capacators at Best Buy, for like $100 a piece. Just make sure you get them professionally installed because if you don't charge them before you put them in, they can explode.
"You never heard of a mind as perverted as mine." -Eminem
Old 07-16-2002, 10:02 PM
are you two absolutly sure?? cause from what i have heard before completely contradicts what you said...man now i am even more confused
Old 07-16-2002, 11:53 PM
ACCSlvCivic ACCSlvCivic is offline
Send a message via ICQ to ACCSlvCivic Send a message via AIM to ACCSlvCivic Send a message via Yahoo to ACCSlvCivic
caps are useless: http://pub51.ezboard.com/fcaraudioknowledgefrm7
read the truth about caps there. i run a 800watt system with no dimming at all (full blast).
1998 Yellow Civic Coupe 5spd EX
Wings West Avenger Kit
Z3 Fenders
c/f hood
Custom Spa Yellow (s2000) paint job
Blacked out taillights
triple beam projector headlights
16" Enkei TBS11s w/Paradas all wrapped around them
Aluminum Front and Rear upper tie bars
Custom CAI, JG 4-2-1 Header, Custom Racing Madalion catback exhaust (2.25") with testpipe
short shifter and Neuspeed shifter bushings
Pioneer DEH-P7300 CD player w/6CD changer
orion 800.4 xtreme amp, 2x 12" eclipse subs, and some 6.5" Focal componts from the polyglass line (6v1)
Next up:
GSR Swap and hopefully some sponsorship?
Old 07-17-2002, 08:03 AM
i guess i dont know enough about audio to understand, but my brother runs a 450x1 on a 12 bandpass and he gets his civic headlights dimmed everytime there is a big bass note....
Old 07-17-2002, 08:37 AM
Audio Guy
it's not really "audio" ... it's physics. If a source, like an amp, draws more power than the alternator can provide - the voltage of the system will start to droop (lower). Amps with real stiffly regulated power supplies can make this even worse, since as the voltage drops it increases it's current demand to keep the power input constant (power = voltsXamps). For some car/amp combos, a capacitor can help to stiffen up the electrical system and prevent those voltage droops when the bass hits that cause the headlights to flicker with the beat of the bass, for others - they do nothing. NOTE: capacitors do NOT increase your SPL or the subjective sound quality.
Old 07-17-2002, 12:57 PM
luti luti is offline
Send a message via AIM to luti
I have a completely different question, but I'll ask you guys since you seem to be a knowledgabe bunch. Why do you need so many watts in a car stereo. I have a many stereos in my house, both solid state and vacuum tube and none of them is over 80 watts, except the surround sound amp, and that is only 250x5, or 50 watts per channel. All of the stereos in my house run on extremely efficient speakers and the sound quality is great. Infact, the Dynaco Dynakit Tube amp is the best sounding, and probably puts out no more than 30 watts a side running on a set of Electro Voice speakers. I also have a Fender Dual Showman, it's a 100 watt single channel guitar amp pushing 2 15" speakers. So my question again is why the need for extreme power in such a small car with such small speakers?
T3/T04E turbocharged ricer.
How Much Power 4ndrms Grand Prix 2 03-02-2002 03:07 PM
how much money will this take from me and how much power will i get from it? kyle95g20 '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 4 12-06-2001 11:49 PM
How much power? Kalect325 Car Audio 3 11-17-2001 12:38 PM
how much power??? lixid Performance 9 11-15-2001 05:31 AM
How much power can standard mod bring you? pche059 Engine 6 09-27-2001 11:43 PM
